AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Samsung D series FBr fix discussion
Samsung D series FBr fix discussion - Page 11
post #301 of 1566
Originally Posted by taiteng View Post
I have a PN59D7000. I would like to try this fix. Should I begin on page 1 of this thread or is there a page that it has been updated?
Thanks for the info!
As zoyd said, all the info is in post #1.
If you want more info on the German remote app, LarryInRI posted a screenshot and some addtional details in post #130. I found that helpful when I did my update. HTH
post #302 of 1566
Originally Posted by agkss View Post
NO Use a wired conection, there's not necesary a wireless LAN adapter or you don't have an easy access to your modem?
Yep just looked at the manual online. I am at work now. Yes there is a LAN connection - so I am guessing that I can attach that to the Uverse LAN - then connect my pc to the LAN and I should be able to ruSamsungcommunicator to work from the PC to the TV?
post #303 of 1566
Originally Posted by Flash311 View Post
I have nothing to go by here but the Avshd disk patterns, and I'm not sure if its what you're looking for here zoyd, but after installing the logic SW update, my brightness setting for my 360 hdmi input only was much different, had to lower it from 57 to 48 for the black clipping pattern. My settings for ps3 didn't change at all though. I used the DeepBlack iso. Probably just a fluke thing I'm guessing.
Has anyone else noticed something similar to this? Should recalibration be required after this fix? The general description of what's changing is that the fix just changes the transient behavior of the brightness shifts. If that's the case, calibration done with static images should be unaffected. But Flash's experience doesn't fit with this.
post #304 of 1566
successful update of my 64D7000. i was already on the 1015 firmware so i did the manual update of the board.
before:
11-02-22
after:
11-11-04
so far in my limited testing the past 20 min or so, no pops. i had to use the less_deepblack file. i first tried the deepblack one thinking that since the 7000 has the deepblack filter, that would be the one, but nope.
post #305 of 1566
Originally Posted by Old Number 7 View Post
Many thanks to Zoyd and LarryInRI.
I successfully updated my 64D7000 using the instructions in Post #1. The German remote app wasn't as hard to use as I was expecting. The picture looks good after restoring all of my calibration settings. I haven't had a chance to watch it much yet, but I have noticed no brightness pops so far.
Prior to update:
Logic SW Version 11-06-07
Logic SW CheckSum 0x2E12
After update:
Logic SW Version 11-11-04
Logic SW CheckSum 0x3796
Firmware 1015
64DS_ITO_Deepblack.bin
interesting that the deepblack file worked on yours. i had to use the less deepblack one. it didnt like the other.
post #306 of 1566
I've added this note to the OP regarding the difference between ITO_DeepBlack and ITOless_DeepBlack
What's the difference between ITO and ITOless?
After some more research I think I've figured out the difference between the two files available for 59" and 64" panels, it's not a difference between the names DeepBlack and lessDeepBlack but rather ITO and ITOless. ITO refers to the inner structure of the pixels, it's an electrode within the pixel. There are also ITO-less pixels that use a different electrode structure (I know, your eyes are glazing over at this point). Anyway the major difference between ITO and ITO-less pixels is that the ITO-less ones exhibit about 1/3 less image retention. So there are two different types of larger panels in circulation right now with different IR characteristics.
post #307 of 1566
64D7000 successfully updated. Thanks to Zoyd and Larry - gotta love the internet!
Tip for dummies like me - if you get the "not available" message, you need to push the info and factory buttons in quick succession.
Observation - The highest brightness setting before dithering noise on black bars pre-update (with 1014.6 applied but no opt.) was 62. Now it's 58.
"Now" = movie mode but no settings, so don't now if putting everything back in will affect it, but doubtful I'd guess?
post #308 of 1566
Originally Posted by areyou4real View Post
Just unpacked a new PN59D6500.
Panel: DS
Stock firmware: 1011
Noticed FBr, so I updated to 1014.6 firmware (Samsung supplied fix) here: http://www.mediafire.com/?9yx26qh8bre98j9
TV went through "optimization" process and now shows:
Firmware: 1014.6
Logic SW CheckSum 0xE09B
Prelim viewing shows FBr gone. Thanks to everyone that solved this.
Is that file from a Samsung USB stick for the 6500 or is it the 7000 rip? I want to verify that the 2 are identical (if they are identical). While the 7000 might work on the 6500, I want to make sure the files are exactly the same. Also, will this FW work on my 51" 6500 as well?
post #309 of 1566
Just realized that my pre/post dithering noise was essentially a "pop." People that don't think they're getting pops could do that as a test.
Before - one click of the brightness from no dithering to dithering was like several clicks on previous display. It's blatantly obvious and can be seen from at least a foot from the screen I'd say. Also, the character of the noise was harsher and brighter than I remembered from previous display.
After update - I thought something was wrong because I couldn't see the noise. Reason was I had to get my nose up there like on previous display. Character was much more subtle - even at many clicks above noise point, still much more subtle than just one click before update.
So if you want to see a brightness pop, just turn brightness down to ~50 and increase one at a time until you see the stars (on black bars in dark scene and with nose up close for full effect.) If it goes from nothing to the sky on a clear night in the mountains with one click, you need to update.
post #310 of 1566
Flash, the difference you are noticing might have to do with the color space for the 360 getting out of wack after the latest xbox dashboard update on some video apps like Netflix. Microsoft has acknowledged the issue and is supposed to be working on a fix.
Try watching a movie on ps3 then on Xbox both thru Netflix. You will notice a big difference in brightness.
post #311 of 1566
good deal. that makes me feel better. i was afraid it was lessdeepblack and i might be missing out on something im supposed to have on my 7000; i guess i just have one of the better panels. no complaints here thanks for all your work and research on this stuff.
post #312 of 1566
I can happily report this worked on my 64D550 (Canadian Model) Worked smoothly but I had to enter the TVs IP manually as it wouldn't detect it.
Props to everybody who helped get this done. I would even suggest you open a PayPal donation as I would happily send a donation as this saved me a lot of headaches and stress.
It may be placebo but I swear my blacks are better now. I used the 64DS_ITO_Deepblack.bin file on my TV.
Mike
post #313 of 1566
Can someone help? I am at step 11 below:
10. Open the Fernbedienung tab
11. On the emulator, hit the Info button and then the Factory button to get into the Service Menu
12. Navigate to SVC and select it
13. Navigate to Logic USB D/L and select it
14. Right arrow to initiate flash (no turning back here)
15. "Updating" will be displayed if the TV accepted the file and this takes a minute or so and then the TV reboots.
16. Recheck Logic SW version.
I seem to be connected to the TV but what do you mean navigate to SVC and select it? Where?
post #314 of 1566
SVC is in the service menu on the TV and should appear after ou hit Info and Factory
Mike
post #315 of 1566
Mike
Ok it finallly showed up. I did the upgrade and it said upgrading for a second then now says no match. The TV has not rebooted. I have tried both USB slots and tow separate sticks.
post #316 of 1566
I successfully updated my 64D8000 last night using the instructions in Post #1.
No brightness pops in blu-ray or Digital TV so far. But I saw some brightness changed in PS3 racing games (in 2D -> 3D mode). Any idea ?
Also noted that my buzzing is much quieter now. awesome !!
Prior to update:
After update:
post #317 of 1566
I hit a button while in the remote console and now the TV is showing Red Green Blue and White screens alternating. Now What? I cannot get it to respond to anything at all. I've unplugged it. It is non responsive although I am sure that there is a series of commands I could issue to get it to stop.
IT finally cycled through it and now everything is back.
post #318 of 1566
Turn it back on, it should be fine.
post #319 of 1566
hamiltonpl,
You have a PN64D550. Have you tried both the 64DS files?
64DS_ITOless_DeepBlack.bin
Are you sure that you have the proper filename and only one '.bin' extension?
Larry
post #320 of 1566
Zoyd,
I haven't been paying close attention to the thread during the past two days, but it appears that now all models have shown success. That includes some from Germany and the UK.
Larry
post #321 of 1566
yes, looks like a global fix.
post #322 of 1566
Originally Posted by LarryInRI View Post
hamiltonpl,
Larry
SUCCESS!!!! I switched to the ITOless version and it upgraded. I am now at 11-11-04 OxF54E
Tested two recorded POPS and they are gone. Thanks everyone especially Zoyd. You Rock.
post #323 of 1566
So the questioin now is WHY are we doing SAMSUNG's job? Seems like an easy enough fix once identified.
Still haven't gotten those two USB sticks but I don't care.
post #324 of 1566
Anyone measure mll with Cinema Smooth on after the update? Just wondering if there is a difference.
post #325 of 1566
Holy shitballs! I am FINALLY pop free on my 59D6500! I hardly ever took the time to appreciate how great the image is on this set because I was constantly distracted. The firmware for the 7000 worked great! Now it is time to update my 51"
post #326 of 1566
Looks like I'm out of luck on my PN43D430. All other models getting a fix but not this one.
post #327 of 1566
Zoyd for president!
post #328 of 1566
I never had the brightness fluctuations, but decided to update the logic board firmware anyway.
I have EU (Nordic, Finland) model PS59D7005.
Prior the update the Logic SW version was 11-02-11, main firmware is 1019.0, BT-G.
I had to use the ITOless_DeepBlack.bin, everything went smoothly during the update process.
Now the Logic SW Version is 11-11-04.
I haven't noticved any difference in image. As I said I hadn't noticed any fluctuations before, and the black level seems to be the same as before.
At least the update did no harm, and I'm glad I know now I have the latest version
post #329 of 1566
Did you try it?
post #330 of 1566
Did the logic board update last night. Played some games and watched some stuff, no pops so far. Kudos to Samsung for finally fixing this.
Now that I've updated to 1014 as well as updating my logic board, is it safe to further update to the latest firmware on my D7000?
