Originally Posted by
janos666
An alternative method:
- enter the SM with your normal remote (US key sequence in the first post or info-menu-mute-power in the EU)
- hit Factory on the network remote (burn-in slideshow will start)
- hit 3Speed (to quit from burn-in mode)
Use the service tools as described in the first post.
Thanks for this very useful info. This will allow 4 series owners like myself to apply the fix despite not being able to use the ruCommunicator, as the IR hex codes for Factory and 3speed have just been discovered on
Samygo forum:
FACTORY
Device Code: 7.7 Function: 59
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0689
3SPEED
Device Code: 7.7 Function: 60
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0689
If you have an IR programmable remote, you should be able to program these in.
