I bought this CW-100 seven years ago but this is the first time I have tried to use it because I never had the right DVD's until now with the clear top surface. I have tried printing on 5 JVC DVD's tonight. The first one printed fine but the ribbon got wrinkled up when that DVD ejected. The 4 times since then I left the front cover up so I could watch the print head. Each time I removed the ribbon from the printer and turned the ribbon take-up hub to bring up a new section of the ribbon and re-installed the ribbon. As I watched the next disk print using a flash light, I can see that the used ribbon is not being wound-up into the ink cartridge and is trailing the head as it moves across the DVD printing. When the printing is finished the DVD is ejected and part of the used ribbon is still stuck to the DVD surface and gets wrinkled-up as the DVD ejects. I have removed the ribbon 5 times after printing on 5 DVD's and it appears that the ribbon winder shaft must not be turning??? I can turn the ribbon hub manually when I remove it from the printer and it seems to turn freely. So I think the problem must be mechanical inside the printer but I can't get the cover off so that I can examine the mechanism. I have pulled off the rubber feet which weren't designed to come off. I think I can glue them back on? I initially removed the 2 phillips head screws on the back of the printer but that didn't let the cover come off. I am afraid I am going to break something that I can't fix if I continue.
Has any of you CW-100 users ever experienced this ribbon problem? Has anyone successfully removed the cover so you could view the mechanism? I am looking for any help anyone can provide.
Everything had gone very smoothly with the software installation and inputing my first title to be printed but everything came to a screeching halt after I printed on my first DVD. That first title looked great, just what I wanted, but I have 29 that need to be printed on.
Dave
Dave
You would think I had put Jello in the crank case instead of oil.
