I will start by saying I work for a retailer and in turn the b&w cm9's and def tech mythos st's fall into this category. I ideally will be using the system for 70% movies and tv and 30% music. The room they are for is about 14x11 with hardwood floors 2 openings on the left side one leads to 2 other rooms the other opening is a staircase that leads upstairs. I currently own a pioneer sc-05, klipsch quintet sl's and a klipsch sw 450. I would really like something more musical and well rounded if that makes sense.
I will be upgrading everything slowly though. First being the front soundstage as I think that will make the biggest difference then either the sub or the rears but my budget only allows me to do it this way. Subs I have been looking into a little already leaning towards either the epik empire or the hsu vt15h but that could change as it is not my focus as of yet. Sorry for the ramble just trying to be thorough. And I am looking for either enforcement if one of the above choices or anything else in the range or less of course.
...here is a video review I made of my system...
