AVS › AVS Forum › Video Components › Home Theater Computers › HTPC starting point?
post #1 of 3
How would this be as a starting point for a computer? I'm looking to stream video and eventually use as a DVR. I have to do it all inexpensively and I can add components in time. My budget is $400-500 total.
http://www.tigerdirect.com/applicati...286&CatId=2628
post #2 of 3
I think you would be better off choosing each individual part, it will save you money and allow you to get what you really need. Under $500 should not be to hard is four needs are just HTPC related. Take a look at assassins sticky there is lots of great info there.
post #3 of 3
Agreed...read Assassin's thread and then BUY THE GUIDES! You will not regret it!
