Hi my friends,
I'm a bit confused. I've read that 72hz is a better refresh rate for some projectors, because it's an even multiple the source. But, I also read in a recent thread that with the LT150 projector only 60hz should be used (and that any other refresh rate will get changed by the projector, causing artifacts).
Is this accurate and, if so, am I correct in assuming that it would also apply to my LT155?
Thanks for the clarification,
Ross
Ross
