AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › OS X software for WinTV-HVR-1950
post #1 of 5
I bought a Hauppauge USB TV tuner from a guy off of Craigslist thinking the company was Mac-friendly and I could use it on Mac OS X (hopefully either OS 5 PPC or Snow Leopard Intel), but I can't easily find any Mac drivers and my EyeTV Lite isn't recognizing it (I already have it set up for a different USB stick so that might be the problem).
Any suggestions?
post #2 of 5
That WinTV-HVR-1950 seems very similar to what El Gato has sold as the 250+...
but El Gato didn't provide blanket support for all of those Hauppauge tuners, it was usually on a case by case basis. According to this page:
http://www.hauppauge.com/site/suppor...ab=6#operating
it doesn't list EyeTV under 3rd party support, so you may be out of luck. Here's a Hauppauge tuner that is officially supported by EyeTV, the WinTV-HVR-950Q, and you'll see that it is mentioned under the 3rd party tab:
http://www.hauppauge.com/site/suppor...t_hvr950q.html
In any event, I suspect you'd need a real version of EyeTV rather than a "Lite" version.
post #3 of 5
There is a list of all the compatible tuners for EyeTV on Elgto's website :
http://www.elgato.com/elgato/int/mai...oduct3.en.html
Rodolphe
post #4 of 5
Thanks for the responses and links. I'm wondering now if the Mac version of Sage might do the trick...
post #5 of 5
Any update on this? Mac only house but I have one too from an old housemate.
  Back to Forum: HTPC - Mac Chat
