AVS › AVS Forum › HDTV › HDTV Technical › Cisco png150n hd cable box issue
post #1 of 3
Hey Guys,
I have the cisco png 150n hd cable box from Comcast. I'm here in Chicago. I went into the setup menu (shut off box, press menu and then press hd zoom) and change from 480p to 1080i but when I shut the box off it goes back to its default setting which was 480. Is there a way to make the box save the settings? Does it matter how I exit the setup menu? Is there certain buttons I have to press when I'm done?
Any help would be appreciated.
Les
post #2 of 3
you can go to comcast cable box user manuals and download the manual. it is at comcast costomer central.
milt
post #3 of 3
milt
I'll give that a try.
Les
  Back to Forum: HDTV Technical
