AVS › AVS Forum › Video Components › Home Theater Computers › Caller ID Notification Working on X64 and in WMC
Caller ID Notification Working on X64 and in WMC - Page 3
post #61 of 92
ok.. i think i got it.. i installed the mce add-in tho.. but am i supposed to configure this somehow? i dont see a tab in wmc and the caller id doesn't pop up even though the w7 caller id settings detect it
post #62 of 92
What did you have to do, I am in the same boat. My bluetooth phone is paired correctly, and shows up in the settings, but I cant get any response in the test, and no popup when I receive a call.
post #63 of 92
i still cant get any response in the test either.. server settings wouldnt even show up before.. but thats because my bluetooth wasnt found
does the phone/desktop bluetooth profile have to be set in a certain way? does the bluetooth have to be set up as a headset profile? a desktop profile?
running out of ideas
post #64 of 92
You do not need to set up any profile, only pair you phone and make sure you are able to see it in the settings under bluetooth tab. Please send me e-mail to support@w7callerid.com and I'll try to help
post #65 of 92
W7 Caller ID supports Windows Phone 7.5 Mango!
I've successfully tested Nokia Lumea 710 running WP 7.5 Mango.
post #66 of 92
I think I'm having a configuration issue. I have opened a support ticket on the Windows 7 Caller ID website, but thought someone here may be able to provide a quick answer. In my scenario, I have 2 HTPCs and 1 XBOX. For this discussion, lets call the HTPCs HTPC1 and HTPC2. HTPC1 is the system that has a modem. HTPC1 has W7CallerIDServerSetup and W7CallerIDMCEPluginSetup installed. I have added localhost and HTPC2 system name in the server configuration configuration on HTPC1. HTPC2 has W7CallerIDClientSetup and W7CallerIDMCEPluginSetup installed. I have inserted the IP address of HTPC1 in the client configuration of HTPC2. The XBOX is connecting to HTPC2 for MC7. Currently, Called ID is working on HTPC1 and HTPC2, but I'm getting nothing on the XBOX.
Quick Config:
System Name.........Role..................Installed Apps
HTPC1.....................Server................W7CallerIDServerSetup and W7CallerIDMCEPluginSetup
HTPC2.....................Client/MCE.......W7CallerIDClientSetup and W7CallerIDMCEPluginSetup
I'm guessing I have this wrong. I originally has W7CallerIDServerSetup and W7CallerIDMCEPluginSetup on HTPC1 and W7CallerIDMCEPluginSetup on HTPC2. However, in this configuration, I was only seeing Called ID on HTPC1.
Also, how do you get pictures in the Called ID window? I'm guessing there are file size, file type, and file name requirements. I couldn't find them on the site.
Edited by chrixx - 6/29/12 at 1:59pm
post #67 of 92
I did some tinkering and I have it somewhat working. This is what the configuration looks like now:
System Name.............Role.................Installed Apps
HTPC1.........................Server...............W7CallerIDServerSetup
HTPC2.........................Client/MCE......W7CallerIDMCEPluginSetup
The only issue I'm having now is that the XBOX only gets notifications if I have Windows Media Center opened on HTPC2. I normally leave WMC7 closed when I'm not using it. Does the W7 Caller ID MCE Plugin only send notifications to the XBOX if WMC7 is running or is there something jacked up on my configuration?
Could I install the W7 Caller ID MCE Plugin on HTPC1 (server install) and add the XBOX IP address in the configuration? I keep WMC7 opened on that system 24/7.
post #68 of 92
MCE needs to be run to push notifications to extenders.
post #69 of 92
W7 Caller ID Video Setup Guide
post #70 of 92
I am ready to pull the switch on this Caller ID.....I am really going to need it for the upcoming election... I have a simple three HTPC setup; only one machine with a modem. I expect to leave this machine on most of the time; the main HTPC does not have a modem. If I understand this, the one machine with modem will forward caller ID info to my HTPC machines running WMC... (My home HTPC are all W7-64) mad.gif
post #71 of 92
Yes, you install "W7 Caller ID Server Setup" on the computer with the modem & "W7 Caller ID MCE Plugin Setup" on the other 2 computers. The server will even send the custom pictures you associate with each phone number to the clients.
post #72 of 92
I installed W7 Caller ID.......I LOVE IT!
I have one server and three clients. It works without a glitch, and that is all I want. smile.gif
post #73 of 92
Version 2.2 has been released. Here are the added features and updates:
- Network notifications support in XBMC format. Now you can use “Notify Pro” application from Google Play (also available for iPhone on Cydia) :
https://play.google.com/store/apps/details?id=net.sakhter.notifypro0&feature=search_result#?t=W251bGwsMSwxLDEsIm5ldC5zYWtodGVyLm5vdGlmeXBybzAiXQ
- MCE plugin and W7 Caller ID Client can now be installed on the same PC.
- Support for the custom formatted phone mask (ie. xxx-xxx-xxx).
- Pause playback, continue playback feature for MCE.
- Custom template for speech message.
- Speech for Media Center with volume control.
- Minor bug fixes.
SMS Support
Edited by sberghici - 10/15/12 at 7:07pm
post #74 of 92
How to add Skype Notifications using VB Script
http://w7callerid.com/setup-skype-notifications-using-vbscript.aspx
post #75 of 92
Holiday Season Savings
Get 25% off of your purchase of W7 Caller ID this holiday season. Use coupon code “holiday2012”.
Offer valid until December 31, 2012.
post #76 of 92
Setup W7 Caller ID to work with Asterisk and SIP VOIP. No modem required.
If you have Asterisk compatible VOIP phone service here are the instructions on how to set it up to work with W7 Caller ID without the analog modem.
• Download and Install AsteriskWin32 from the following location
http://www.asteriskwin32.com/dwn.php?script=0.66
• Download configuration templates
http://w7callerid.com/asterisk.zip
• Copy ‘extensions.conf’ and ‘sip.conf’ files to the following folder:
C:\cygroot\asterisk\etc
• Add a new Network Listener:
• Update IP address and Port of ‘extensions.conf’ with values from previous step and “sipuser” with your VOIP user name.
• Update “sipuser”, “password”, “10123456789”, “vbuzzer.com:80” of ‘sip.config’ with values provided from your VOIP provider. You phone number goes where “10123456789” is and “vbuzzer.com:80” is your provider IP address and port.
• Run C:\cygroot\bin\asterisk.exe. Later you can setup it to run as a windows service(run from the command line as administrator “C:\cygroot\bin\asterisk.exe –I”)
In the next release a drop call and block unwanted calls functionality will be added for full Asterisk support.
post #77 of 92
I am integrating this great software into my home automation system which is based on EventGhost. Using the vbscript approach, I am able to trigger events when a call comes in, passing caller id data to EG. Works great! Even greater would be to also be able to trigger events on the call ending. Is this possible? The MCE plugin seems to be able to resume play on call ending, so the detection capability must be there in the software.
post #78 of 92
call ending event is not available in the current version. MCE resumes play based on popup duration setting. I'm adding this to todo list.
post #79 of 92
Any chance of a MediaPortal plugin?
post #80 of 92
I'm integrating W7CID with MediaPortal through EventGhost, using the vbscript approach and the MP EventGhost+ plugin. Should provide the same functionality as the MCE plugin.
Edit: works beautifully! I now have caller ID details and pictures poping up in Mediaportal, current content paused, a ring tone played through the speaker system and the light dimmers turned up on all four MP clients around the house. All from one W7CID server, connected to the land line and four iPhones.
Edited by mickelin - 1/12/13 at 6:07am
post #81 of 92
Almost done:
I'll be able to release it tomorrow. Same functionality as MCE version - drop call,pause playback, speech
post #82 of 92
Brilliant!
post #83 of 92
Originally Posted by sberghici View Post
Almost done:
Done:
http://w7callerid.com/downloads.aspx
post #84 of 92
Works perfectly, great job! Only thing is the picture is misaligned in the skin I'm using. Are you using the default wide skin in the pic above?
post #85 of 92
Yes. Which skin are you using?
post #86 of 92
I
I use StreamedMP. The message box turns up center screen, with the picture below. I tried the default wide and it looks better, but the picture is sticking out to the right of the message box. I guess it has to do with the size of the picture. Is there an ideal picture size I should use?
post #87 of 92
I
I guess the following skin has incorrect position for image:
skin\StreamedMP\dialogTVNotifyYesNo.xml
I've updated it and it shows image correctly:
post #88 of 92
Perfect, thanks!
post #89 of 92
post #90 of 92
Version 3.0 released. Core Application Runs As a Windows Service!
- W7 Caller ID application has been split to Windows Service and Tray Application.
- Tray Application can be run on the remote PC.
- Configurable popup size – standard/small.
- Resume Media Center/Mediaportal play after call end (supported for Smartphones only).
- Ability to run VB Script on call end event.
- Support drop call and blocked numbers for Asterisk.
- Minor bug fixes.
Small popup:
