AVS › AVS Forum › HDTV › HDTV Technical › D* HR-24-500 Issue: Pink/magenta line showing at top
post #1 of 3
When the top banner leaves at times I have pink/magenta pixalization show up just at the top of the screen, then leaves. I am using also a DVDO Edge. I bypassed the edge and the issue still happened. My TV is a Pioneer 141 Signature. I know the HR-24 puts out a color space that is RGB (16-235). I have tried verything and cannot get rid of it. This pixalization does not show up when using Blue Ray, etc. Any help would be appreciated. Thanks.
Jim
post #2 of 3
Topic title made more specific, though "line" might be an overstatement..
post #3 of 3
I have had this since getting the HD GUI. It is on all three of my DVRs, 2 HR20's and 1 HR22. Mine is yellow and white looking like the coding for closed captioning. I believe it only happens on "action" stations, ones which can display sports scores, etc.
I put a message about this on dbstalk. No one responded.
In my case I have found that simply pressing the "exit" button removes it.
SMK
  Back to Forum: HDTV Technical
