Newbie looking for what antenna to get.
I have been researching an in attic installed antenna (preferrable to on roof). I am looking for advice on a suitable antenna and, if I will need a preamp. My goal is the major networks, pbs and fox in high definition. They look like they are on the same azimuth so I do not think I need a rotator.
Location- Newburyport, MA 01950
We will be providing antenna service to one TV.
Inside attic mount if signal strength warrants (from what i read, I should expect a 10-30% drop in signal stength through the roof (traditional construcion - boards with asphalt tiles).
From TV Fool http://www.tvfool.com/?option=com_wr...0b866aad119a71
FCC site give me four bars of signal strength for-
WENH PBS 11-1 Hi-V
WPXG ION 21-1 UHF
WCVB ABC 5-1 UHF
WBZ CBS 4-1 UHF
WGBH PBS 2-1 UHF
WGBX PBS 44-1 UHF
WFXT FOX 25-1 UHF
Three bars of signal strength for-
WSBK IND 38-1 UHF
WUNI UNIVISION 27-1 UHF
WLVI CW 56-1 UHF
WMFP IND 62-1 UHF
WHDH NBC 7-1 UHF
WZMY MYTV 50-1 UHF
WMUR ABC 9-1 Hi-V
WNEU TELEMUNDO 60-1 UHF
WMTW ABC 8-1 Hi-V
WMEA PBS 26-1 UHF
WBPX ION 68-1 UHF
WUTF TELEFUTURA 66-1 UHF
Thank you for your help.
WENH PBS 11-1 Hi-V
WPXG ION 21-1 UHF
WCVB ABC 5-1 UHF
WBZ CBS 4-1 UHF
WGBH PBS 2-1 UHF
WGBX PBS 44-1 UHF
WFXT FOX 25-1 UHF
WSBK IND 38-1 UHF
WLVI CW 56-1 UHF
WMFP IND 62-1 UHF
WHDH NBC 7-1 UHF
WZMY MYTV 50-1 UHF
WMUR ABC 9-1 Hi-V
WMTW ABC 8-1 Hi-V
WMEA PBS 26-1 UHF
WBPX ION 68-1 UHF
