Power handling: 250 watts RMS/500 watts max • VCdia: 2-1/2" • Le: 1.94 mH • Impedance: 4 ohms • Re: 3.23 ohms • Frequency range: 23-200 Hz • Fs: 23 Hz • SPL: 89 dB 2.83V/1m •Vas: 4.12 cu. ft. • Qms: 5.59 • Qes: 0.44 • Qts: 0.41 • Xmax: 9.3 mm • Dimensions: Overall diameter: 12", Cutout diameter: 11", Depth: 6".
if this was in a 2.45 ported box and a 4x 12-14inch port. 300 watt bash amp
i have no software to figure this out your help would be great
thanks
thanks
