AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer VSX-918V No center or surround sound
post #1 of 12
i just recently bought my Pioneer VSX-918V receiver and I just can't seem to get the center or surround sound to work. I went in troubleshooting in the manual and did everything it suggests but i still can't seem to get it to work. If i go into the channel levels where you can test the levels of each speaker i can hear the test sound coming from both the center and the surround speakers, but when i try playing music, watching tv, a movie ect. i get nothing out of them. Any suggestions?
post #2 of 12
bump
post #3 of 12
Hi Rubixcube22, more info about your setup and settings would help.
post #4 of 12
uhhh, I have two Acoustic Audio 300w surround sound speakers, an 150w Acoustic Audio center speaker, a 90w samsung subwoofer, two MA Audio front speakers, and a dual speaker MA Audio Synergy connected. I have my Phillips flatscreen hooked up through DVR/VCR in, my xbox 360 hooked up in CDR/TAPE, and i have my turntable hooked up in AUX. I didn't lower or raise any of the channel levels. I have the subwoofer set at yes, and all the other speakers set at large.
post #5 of 12
Appears you're using RCA (white & red) audio cables. If so that is the reason you're getting 2Ch.
post #6 of 12
what should i do to fix this?
post #7 of 12
For the Xbox 360, connect an optical cable Xbox 360 to receiver OPT-1.
Do you have a cable box or OTA (tv antenna)?
post #8 of 12
cable box
post #9 of 12
first thing, set all your speakers to small and let your subwoofer handle the low frequencies.
second choose a sound mode like Dolby Pro Logic II or DTS:Neo6. Then you'll get sound from all your speakers.
Use optical connections from your cable box if it is HD and optical from Xbox 360 to receiver.
post #10 of 12
how do I do that?
post #11 of 12
i did exactly what you said. I figured out how to switch it to dolby pro logic and used an optical connection, but i still don't have sound in all my speakers...
post #12 of 12
Rubix... how did u get this to work? i have a new SC-67 and i can't seem to get the sound on surround or center speakers during the test tone or a movie.
regards,
Hassan
