Originally Posted by
HiFiFun
Owen James Cameron is moving to New Zealand. Perhaps you could drop by and see him to put things into perspective. Ask him if he is going back to NTSC or PAL?
No one is suggesting we go back to lower resolution video formats but understanding the limits of what we have and how to best display it is useful.
HiFiFun
Seriously people look at computer data screens just as much as we look at video. Did you forget this aspect?
I have used a HTPC as my only playback system for 12 years and for 6 of those used triple gun CRT projection for display. The CRT was the only display attached to the PC so it was used for everything. CRT was far from ideal for PC text but that did
not stop it producing good video images.
Even cheap low res data projectors work great for PC use but they leave a lot to be desired for video. Current 1080 home cinema models dont seem to have any problems with PC text and graphics.
HiFiFun
The competition (flat panels) have no lens to soften the image quality or three panels with all sorts of added (and easily observable) alignment distortions. Projection system should be transparent as possible or else consumers will naturally switch over. This means the optical path should be of camera quality.
When I view a flat panel TV at the sort of viewing angle I do a projection screen I don’t like what I see at all. Those perfectly sharp pixels and poor fill factor give the image a harsh digital look that I find objectionable.
Video is very dirty and distorted at the pixel level so sharper at the pixel level is definitely not better in my book.
HiFiFun
Any softening of the image should be left to the engineers. The transmission, storage or reproducing display system should in in no way alter the image.
That depends on whether you prefer a clean smooth analogue looking image that better represents the source or a harsh distorted digital looking one.
HiFiFun
HD camera and mastering techniques are constantly evolving. Most of us can see the result of improved MTF/contrast in every stage of the capturing and mastering chain. Thank you James Cameron for raising the standards.
No doubt cameras and mastering techniques will evolve, however the limits imposed by digital sampling and its required low pass filtering will remain.
HiFiFun
Audio went through a similar evolution. Digital filters improved greatly over time and are able today to capture high frequencies close to the Nyquist limit. Again, its the mastering engineer who selects to add low level dither or increase bit depth.
Consumer audio systems should not be adding noise, distortion or resample. Realizing just how bad mp3 degraded a generation of listener enjoyment, Steve Jobs was planning to go to 24 bits. These are the leaders who are making our lives more enjoyable.
The distortions the human ear can perceive at 20KHz after being reproduced by a speaker are very different to what the human eye perceives when looking at HD video projected on a large screen. Problems that would go unnoticed in audio are very noticeable with video.
Resampling or more accurately oversampling has been used for CD audio for years to improve perceived quality, so has upscaling for SD video. Upscaling HD video is also beneficial, although the improvements are less obvious than with upscaled SD, we don’t gain any resolution but we can get a cleaner more analogue looking image.
A similar result can be achieved with double scaling, first up with sharpening and then back down to 1920x1080 for output.
HiFiFun
This is what high fidelity or high technology is all about. People will pay for the best quality experience. Hopefully the very expensive Sony 4K display will resolve 4K resolution. (the less expensive Sony projector have issues resolve 1080. see Kris Deering's review of the 95ES). If not 80-90" flat panels will - and for much less.
A 4K projector does not guarantee a better quality viewing experience. Unless your viewing angle is large enough for the pixel structure of 1920x1080 to be visible more pixels are of little benefit other than bragging rights, other aspects of performance will dominate.
The Sony will likely resolve 4k with good MTF but 4k video will offer much less improvement over current 2k than people think and virtually all of the improvement will be in greater MTF below 2k.
