AVS › AVS Forum › Audio › Speakers › klipsch rf 62ii as rears?
post #1 of 3
I just got a pair of Rf 62ii over a month ago but now I wish I had gone with Rf 82ii. I have a friend looking for speakers too and willing to buy my 62ii. But should I just use the 62ii as rears in a 7.1 setiup? Can the Rf 62ii be used as rears or bookshelf speakers are better?
post #2 of 3
... should I just use the 62ii as rears in a 7.1 setiup ... or [are] bookshelf speakers are better?
Yes, the RF-62 II's can be used as rear surrounds but, IMO, it's a bit of overkill to use towers for that purpose.
post #3 of 3
Using towers as surrounds is not necessarily overkill simply not as common in home theater.
I listen to quite a bit of multichannel music in addition to movies and having direct radiating towers sounds better for me.
My surrounds are the RF-82s and they work marvelously.
Best Regards
KvE
  Back to Forum: Speakers
