The old 5400's were originally titanium but later on while manufacturing later batches they had problems with their supplier and the dishes were often defective. They then switched to aluminum. The AudioPulse branded LMS-U's were also aluminum, iirc.
Ah, I see Mr. Hurd got it before me.
Originally Posted by michael hurd
Old early 5400's ( prototypes) were aluminum cones, then they went to titanium which was something like 22% thinner, but heavier as well as stronger. They said that there was a high cosmetic defect rate with the ti cones, along with the high cost. I suspect that helped the move back to aluminum in the newer versions.
It's your call though but @ 4,400w the LMS-U is out of rated (38mm) Xmax ~23hz in a 4cuft cab and possibly out of Xmax by 30hz in the same cab if we reduce the Xmax to what was measured by Notyt and Josh Ricci recently of around 33mm. Just sayin', you know... go for it but you'll have to filter out the uber deep bass from the world's most uber driver. Kinda lame, imo. I'd rather just use 2kw and make the up the extra SPL elsewhere. But I'm weird and like full bandwidth audio.
