AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Audioengine A5+ and AS8
post #1 of 5
Hi,
I'm trying to achieve a setup where the sub handles virtually all lower-end frequencies and the A5+ just focuses on the upper mids and highs. My setup is a PC optical out into a DAC. DAC analog out into the A5+ inputs. A5+ varibale audio out to the AS8 inputs.
The problem is despite setting crossover at 130 the A5+ are still outputting low-end frequencies and I'm getting a "double bass" effect. I verified that the A5+ was still playing low-end frequencies by setting the xover at 130 and turning the volume completely down on the sub, instead of hearing thinner sound from the A5+, I heard the full range. Checking the xover section on page 6 of the AS8 manual it should not behave like this. Any idea why the A5+ continues to play the full range. Do I need a receiver to manage bass? I thought the sub would handle it.
I also tried an alternate connection method with the same result (A5+ continues to play full range). For this connection I tried PC Optical out to DAC. DAC analog out to the AS8 inputs and AS8 outputs to A5+ inputs.
post #2 of 5
Originally Posted by jav1 View Post
Hi,
You might want to contact the people who made the product you bought.
post #3 of 5
Yep, have an email into them... I'm hoping to hear from anyone who may have an identical setup..
post #4 of 5
The A5+'s internal crossover doesn't have a low frequency cut off and will play full range if given any chance, but im sharing your pain bro, it would be great if they did. The best i can figure is to have one line running to the A5+, set your crossover for them AND then run a separate line for the sub.
post #5 of 5
Hi,
You need a electronic crossover like a Behringer DCX 2496.
The problem is that the most economical way to get such a thing seems to be by obtaining a low end AVR.
The practical and economic aspects of that solution aren't so good.
You end up buying a lot of hardware you bought the AE speakers to avoid.
Someone needs to make a box that is the DSP and inputs of an AVR with line outputs and no power amps. Trouble is, doing that for less money than a low end AVR is probably mission impossible.
Welcome to the wonderful world of economies of scale!
