Originally Posted by Bob Black
Ron, thanks for all your help. I just installed my Sony projector last night and I'm blown away! Right out of the box it has a fantastic picture, and 3D is great.
I had one other question however. I set up the system as you suggested...I bought the Panasonic 310 with the dual HDMI outputs. I bought a 25' high speed HDMI cable and connected it directly to the pj's HDMI 1 input. The other HDMI output from the Panasonic (HDMI-Sub) I connected to my Integra processor, along with the additional sources (PS3, HD DVD, etc). Then I used a standard HDMI cable from the Integra's output to the pj's HDMI 2 input.
Last night I kept trying to get audio out of the Panny unsuccessfully...it would display the video but the Integra would not recognize the sound. I kept changing the Panny's audio and HDMI settings trying to remedy the problem, but it would not ouput the sound. Later, I discovered when I switched to the pj's HDMI 2 input, the video disappeared but the audio was playing. So I ended up removing the standard HDMI cable from the Integra (which had been going to the projector's HDMI 2 input) and suddenly I had video and audio! 3D works perfectly and lossless sound is perfect, but I don't really feel like needing to fumble with removing and plugging in the HDMI cable every time I switch components. Is there something I'm missing here?
Why do you have two HDMI cables going to your projector? The Integra should be doing all of the video switching for you. You shouldn't need to use any other input on the projector except HDMI 1.
