Hello, I have a pretty old setup in my apartment. It has served me well for almost ten years probably, but now I am starting to have issues. A few months back I noticed I would get an occasional popping sound from my speakers, usually a minute after turning on my system. It usually pops once and then the speakers work great. sometimes it pops after being on for awhile. sometimes it doesn't pop at all. I decided the other day to run the test tone to make sure they all work and the speakers all passed the test. Only problem now, is my subwoofer doesn't work anymore. It's almost like the test tone screwed it up or something. If the sub is turned off and I plug it in, all I get is a humming sound and a very slight burnt smell coming from the sub. It doesn't matter if I turn it on or off, same affect. Does the same thing if it is plugged into my receiver or not as well.
Any ideas would be greatly appreciated, thanks.
I am using a Sony STR-DE675 Receiver
My speakers are Cambridge Soundworks movieworks
My sub is a Cambridge Soundworks Basscube 10S
