AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Digicon & Belden
Digicon & Belden
post #1 of 7
Does anyone know where I can find out which digicon compression fitting, either green or blue is the best match for Belden 7915a coax?
post #2 of 7
Got Google? http://www.arrisistore.com/digicon/D...tion-Guide.pdf and http://www.belden.com/techdatas/english/7915A.pdf. Blue.
post #3 of 7
7915a is a tri-shield cable. You're gonna have to use the green ones. Blue is for dual-shield only.
post #4 of 7
Not according to Arris: http://www.arrisistore.com/product.php?pid=708860
although the green ones will work too: http://www.arrisistore.com/product.php?pid=708861
post #5 of 7
Thanks! I always thought they were dual only. Maybe they changed them the same time they changed the green to universal.
post #6 of 7
I had picked up 2 bags of digicon blue & green at a yard sale for $3. Tried both on the Belden cable, they both worked. So was wondering which ones were preferable to use.
post #7 of 7
The blue ones are for dual and tri-shield cable, while the green ones are for tri and quad-shield cable. So, for tri-shield cable, you can use either.
  Back to Forum: Home A/V Distribution
