AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › /// Reference Blu-Ray Demo Disc - BD9 (DVD-DL Media + BD50) \\\
/// Reference Blu-Ray Demo Disc - BD9 (DVD-DL Media + BD50) \\\ - Page 40
post #1171 of 1344
Thank you for this demodisc!
I´ll be seeding the full disc as long as possible. Been uploading 60GB since yesterday when i started downloading it so I guess it´s doing some good biggrin.gif
post #1172 of 1344
Stay with us. The next installment is almost ready.
Michael
post #1173 of 1344
If you are curious Landshark1 posted some of the Surround menus on his build thread. Getting close.
http://www.avsforum.com/t/1347041/my-new-home-theater-2-0-staggered-wall-ht/300#post_23164450
post #1174 of 1344
Thank you. I'm trying to get it, but don't use torrents, so kind of suck at it.
post #1175 of 1344
Downloaded the BD disc over two days and now seeding - slowly. I have not yet burned a disc. Also, I want to put it on a stand alone hard drive and connect it to my OPPO 93. Thanks for all of the hard work y'all put into this project. I'm excited to see the new project.
Paul
post #1176 of 1344
Finished downloading today and am also seeding... at least for a little while. smile.gif Have not burned the disc yet, still waiting for my 50GB blanks to arrive. Looking forward to the next demo disc.
post #1177 of 1344
I'm pretty new to this... How/where do I get the torrent download from? I downloaded utorrent, I type Reference Blu-Ray Demo Disc - BD9 and no torrent. mad.gif I have been at this for well over an hour. HELP!
post #1178 of 1344
First 6 posts, page 1
post #1179 of 1344
I've read that several times. "Get the individual header/tracker for the torrent". I don't know where that is located. I've searched Torrent sites and I get nothing.
post #1180 of 1344
Just keep going, you stopped to soon.
2nd post just after the parrograph, you need to download that file and renamed/delete the TXT extension. Then unzip ... Password is "AVSFORUM"
post #1181 of 1344
biggrin.gif Man that was tuff! Sorry for my lack of patience... You are a Rockin Roll Superstar !
post #1182 of 1344
Still can't get it to play on my oppo. Any suggestions anyone?
post #1183 of 1344
Have you asked at the oppo thread on the bluray players side of the forum?
You can ask if anyone could walk you through on how to play a BDMV folder structure from a USB drive.
post #1184 of 1344
Yeah I have the latest firmware. It shows that the USB drive is in on the front display but I can't navigate anything on it
post #1185 of 1344
My understanding is that the Oppo 103/105 used to be able to play BDMV folders from usb drives, but licensing authorities forced Oppo to remove that feature from the latest firmware.
http://watershade.net/wmcclain/BDP-103-faq.html
post #1186 of 1344
And I tried running this 38.6gb unzipped folder thru multiavchd and it wants to turn it into a 129gb folder? Something isn't right here haha
post #1187 of 1344
I've read somewhere that in order for the Oppo to run BDs through a USB hardrive or thumbdirve the folder where the BD resides needs to be called AVCHD. Not sure if this has been disabled with the new firmware, but its worth a try.
With regards to running the BD through MultiAVCHD in authoring mode - I believe the needed space is a software bug, it just requires the exact same space.
post #1188 of 1344
Only iso don't work, folder structure work fine on a usb stick
post #1189 of 1344
The Reference 2 Demo Disc is ready to be launched...
The new disc can be followed at the following thread
http://www.avsforum.com/t/1469192/reference-2-blu-ray-demo-disc-bd9s-bd50
post #1190 of 1344
Sweet...........thanks SuperLeo!!!
post #1191 of 1344
I was just coming here to ask about this very disk, sweet sweet news.
post #1192 of 1344
Is there any other way to get these files. Without Torrent. I use netload.
And I made a basic calibration Bluray Disc. And .mkv (Very small) To be used with the DISNEY WOW Disc and BLUE FILTER LENS to Calibrate
Your 3D TV or PROJECTOR.
So I thought I'd share.
Very interesting, work you've done here. Thumbs up!
SOLOFORCE 3D Blu-Ray Calibration Pattern Disc for 3D Blu-Ray Players
(will throw your projector into 3D AUTO mode) Image will look 2D except for OPENING title.
IT WILL SWITCH DEPTHS. BECOME GHOSTY cause of the BRIGHT LETTERS ON BLACK. (Normal)
If you know how to calibrate your TV/Projector, and have the BLUE FILTER Lens
(Like the one from the WOW disc) you will be able to Calibrate COLOUR, and TINT, more accurately.
This is the link for the .ISO. Burn this to a BLU-RAY Disc, with the proper .ISO burning program...and you are set.
http://netload.in/dateiC6mazm1glI/SoloForce3D.iso.htm
SOLOFORCE 3D Calibration Pattern .MKV file for SBS Mode on your TV/PROJECTOR
Switch your TV/PROJECTOR into SIDE BY SIDE MODE when using this file.
Some Blu-Ray Players with USB accept .MKV Files. or Media Centers.
Note: The 3D settings for your projector are different when using SBS or AUTO.
The only way to calibrate in AUTO is with a 3D Blu-Ray Calibration Disc as above.
(That's what I've found anyway)
This is the link for the .MKV file for SIDE BY SIDE Calibration.
http://netload.in/dateiLmKS5nfC4d/SoloForce3DCALIBRATIONSBS1080.mkv.htm
SOLOFORCE 3D Calibration Pattern .M2TS file for SBS Mode on your TV/PROJECTOR
All the same information about the .MKV file but in .M2TS format.
.M2TS formats can play from a USB on your playstation 3. And again this is for SIDE BY SIDE Mode
This is the link for the .M2TS file for SIDE BY SIDE Calibration.
http://netload.in/datei5XWWgRzRsq/SoloForce3DCALIBRATIONSBS1080.m2ts.htm
GOOD LUCK!!!
iMIKE THEATRE
post #1193 of 1344
Thanks for your work
Is that possible to have an FTP or torrent link ?
post #1194 of 1344
Yes, because I uploaded it here, with NL links, just refreshed today : http://tehparadox.com/forum/f119/home-theater-demonstration-disc-2011-bluray-2814888/
Edit: sorry, that's for Home Theater Demo Disc V2.0
post #1195 of 1344
Got it. Thanks!
iMIKE THEATRE
post #1196 of 1344
Can anyone confirm if the DVD version will play on an Oppo BDP-103? I made
a disk but will not play on a store demo Oppo even though it played fine on my denon bluray. Do I have to patch it for it to work or maybe the player needed firmware updates??
Edited by DAlba - 4/28/13 at 7:40am
post #1197 of 1344
I am loving the music section, especially josh groban( what media is this from?) Chicago and Styx. Can't see how Justin is reference, but then again I only forced myself through it once.......
It would be great if you could list the discs the clips have been lifted from we're included though, especially for disc two:-)
Steve
post #1198 of 1344
All clips are taken from Bluray or HDDVD, all are 1080 either P or I.
The Josh Groban song is from his "Awake Live" disc.
The Reference 2 disc includes an information box with more information. You can follow the link below to the Reference 2: Blu-Ray Demo Disc.
And GOOD JOB going through the whole disc! That gave you the complete perspective on what the disc encompasses.
post #1199 of 1344
So i have the full disc. I want to burn it to a bd50, however im a little worried bc i tried playing some of the files on my pc and id say roughly 50% of them work. Any suggestions?
post #1200 of 1344
Code:
What software did you use to play the clips?
That's why is suggested to have a bd-re, you can do a test burn on one these if not sure. I just saw a pack of 5 bd-re(s) for less thn $5 per disc on amazon.
