Originally Posted by alittletank
I need a little help. I used imgburn to create an ISO file but cant get it to play in VLC. either I used the wrong files to create the ISO or vlc is the wrong player to use...
I thought that VLC would play ISO files. I am downloading TMT to try the trial. that should tell me if the ISO is good or not.
I don't think VLC plays ISO files by itself... I believe you probably need DaemonTools or somesuch to mount the ISO before VLC could play it.
And that's a big IF on whether VLC can play BR material directly or not, never tried.
