Originally Posted by superleo
First step before you can use the files is to extract/unpacked them. You need winRAR or similar software for this.
Once you've installed the program go to the folder where the files where download, right click on the first file for the disc you want to extract and click extract file, this will launch a wizard, just follow the wizard and once it's done THEN you can use the files/disc.
Ah I knew I missed something thanks.
Ok, got the winRAR from 1st post, right click but don't see extract/unpacked option.
These are the options when right click:
Explore
Open
Share
Add to Archive...
Add to "RAR_Bass_Disc.rar"
Compress and email...
Compress to "RAR_Bass_Disc.rar" and email
Send to
Cut
Copy
Create Shortcut
Delete
Rename
Properties
