AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › /// Reference Blu-Ray Demo Disc - BD9 (DVD-DL Media + BD50) \\\
/// Reference Blu-Ray Demo Disc - BD9 (DVD-DL Media + BD50) \\\ - Page 25
post #721 of 1198
Originally Posted by superleo View Post
The Full BD50 can only be burned to a double layered bluray media disc and as such a bluray burner is needed.
The individual segments of the disc (bass, animation, music, surround and visual) can be burn to a double layered DVD.
A remainder; the downloaded file needs to be unpacked (unzipped) first before you can do anything with it.
Is there anything different about the instructions in the first post if you want to burn to Blu media?
post #722 of 1198
None, other than... the media (and the burner need to be BD of course)
post #723 of 1198
Good. I just ordered an external Blu burner and some Blu and DVD media. I'll also use it to make family discs....I have nieces and nephews out the ying-yang. All Blu burners are also players yes?
post #724 of 1198
Yes, but not all BD readers are burners.
Like the old saying that all dancing shoes are black, but not all black shoes are dancing ones.
post #725 of 1198
For anyone who has downloaded and burned the full BD50 file onto Blu media........any advice on the process or tips from unpacking the torrent file to completing the burn? The media is expensive and I'd like to get it write on the first try if possible. I'm waiting on delivery of Blu burner and media.
Like these two parts:
- Determine which index files you need for your player.
- Replace index files and movieObject files if needed
Not sure exactly what that means or if I need to do anything there if I want to burn the full disc???
post #726 of 1198
Unpacking the file alone will take from 20min up to over an hour depending on your type of processor. Once unpacked you'll have a folder with the BD structure ready to be used or burned. Changing the index files is relevant only to the individual segments and burning the content into DVD-DL media.
It has been mentioned before, not scientifically proven, that if you burn at a slower speed you reduced your chances of a bad burn (making coasters). I personally burn at 2x with no problems, but that is more of a personal preference and personal experience.
post #727 of 1198
Thanks superleo. Is unpacking as simple as opening WinRAR and just selecting the BD50 file/torrent and then let it do it's thing?
post #728 of 1198
Guys, could you please give me a hand here and set your accounts to seed the file?
It will be highly appreciated.......thanks!
post #729 of 1198
Is it as easy as starting utorrent again? If so I can do that....I've already downloaded the full BD50. If not, tell me what I need to do and I'll be happy to.
post #730 of 1198
Kevin,
Yes, I think you just need to open your uTorrent app and let it run. Look at the right of the downloaded file, right next to the file name and it should say seeding.
Thanks!!!
Edited by cr136124 - 7/20/12 at 2:02pm
post #731 of 1198
Kevin,
Thanks!!!
Done
post #732 of 1198
Done
Thanks bro!
Is the file showing a "seeding" status?
post #733 of 1198
Thanks bro!
Yup, and the upload speed is showing a solid 115-130 kB/s
It took me about 4 days to finish on my connection for the full BD50 file.
post #734 of 1198
I was hoping to burn that disc in the next 5 minutes or so..............just kidding!!
Glad I'm doing it on my desktop PC (wired) and not on my laptop (wireless). It seems my desktop machine will be running for few days then...wink.gif
Thanks for the help Kevin, and hopefully other forum members will join this effort.
Cheers!
post #735 of 1198
Cheers!
post #736 of 1198
I could use a seed (on the BD50 version)... no seeds showing
post #737 of 1198
I find people are seeding the individual downloads more. Took me about a day to download 4 of the individual discs.
post #738 of 1198
Cheers!
Ok, after 3 full days the file has been downloaded and now I'm currently seeding for those of you hoping to download it too.
Now, I will give it a try to burn it by sections on DVDs. Hopefully, I will be able to find a good deal on a BD burner on the net.
Cheers!
post #739 of 1198
Cheers!
If you are definitely going to use DVDs, then you don't need a Blu burner. Dual layer DVDs and a DVD burner that will burn dual layer I think are all you'll need.
post #740 of 1198
True!
Well, I'm thinking now only on burning a DVD for the bass demo. But, I would like to have everything in one single disc and therefore Bluray is the way to go.
BTW - what is the post number in which the instructions for DVD burn are listed?
post #741 of 1198
True!
Everything should be in the first post. If you have any questions beyond that, just post them and one of the fellas with the know-how will chime in.
post #742 of 1198
Cheers!
If you have the BD50 Full file its the complete disc, all 5 segments and the top menu. However, you can not separate the segments from this file. If you want to burn to DVD DL, the individual segment files are required.
If you have all 5 segments... You can create the complete BD50 from these segments by downloading the "DIY BD50 from files" and following the instructions.
post #743 of 1198
Alright, need some help.
Tried on two separate discs now, both the same.
I let imgburn format the disc itself, is that the issue? The folders (both BDMV and CERTIFICATE) were located and selected. Verify was selected. Instructions on page 1 were followed to a T (I think).
The discs do not play, nor are recognized by my HTPC (The data appears there, but nothing will play it). The discs show data amounts though as depicted.
What do I need to do different? This is my first time using a RW, I have burned ScubaSteves 2.0 demo thrice on non RW discs and a few other BD copies. Not totally new to Imgburn.
Each time Imgburn told me there was XXXXX miscompares which I knew was bad but didn't know what it means.
So, let me know what you guys think. All of the m2ts files play via J River Media Center when individually selected inside the STREAM folder......
This was the full BD50 download.
Thanks for the assist.
post #744 of 1198
What I've read about this error message is that there might not really be an error there.
Check if there are any firmware updates for your drive.
Use the latest Imgeburn version
Do not use verify
I would re do a full format check for the items above and re try.
post #745 of 1198
I can't remember if I commented in this thread or not, but thank you SuperLeo for your hard work in putting this disc together. It is great and I ended up burning copies for my dad and brother so they can demo their systems as well. We all love it.
post #746 of 1198
post #747 of 1198
Do not use verify
I know my ImgBurn version is an update old, and I'll retry like you suggest.
Thanks for the tips!
post #748 of 1198
This compilation looks pretty amazing, anyone out there fancy seeding the full bd for me please? Looks like there aren't any seeders out there currently?
Cheers!
Ash
post #749 of 1198
I'm currently seeding to 5 of 5 peers... -TD
post #750 of 1198
Cheers!
Ash
If you see no seeders is that most likely your router/port is set up incorrectly. Check your router port and run the test to assure that the client has connectivity.
