AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › /// Reference Blu-Ray Demo Disc - BD9 (DVD-DL Media + BD50) \\\
/// Reference Blu-Ray Demo Disc - BD9 (DVD-DL Media + BD50) \\\ - Page 32
post #931 of 1344
Originally Posted by saprano View Post
Amazing thread. Subcribed.
I don't think i will be able to download this this though. My computer doesn't have a DVD burner. It's slow as ever too. Only 128mb of ram. frown.gif
Anybody want to send me a copy? I would GREATLY appreciate it!
EDIT- Really, really would be great. Thanks.
EDIT 2- I use a PS3 as my BD player. Would the disc work?
128 MB of RAM? How did you even post on this forum!?
post #932 of 1344
Haha. Im using my PS3.
Anybody can do this for me?
post #933 of 1344
So I am not sure if I had a case of "beginners luck", but I just got a blu ray burner and some regular 25g media, so I figured I would try my hand at one of the single discs. I decided on the Bass disc- followed the directions to the letter (although I didn't see a "certificate" folder in this particular one...) Burned and tested- PERFECT. (using an 80GB PS3, original style)
SO- I go to do my second disc- the Animation disc. Same procedure, except i get an "invalid disc" error. Patched from the backup folder, same result? Am I missing something, or is it just this "hit and miss" with the playing of burned BR on PS3?
Thanks for any input- loving the bass disc- HUGE KUDOS to the OP for providing this! Just hope I can sort out the rest...
MR
post #934 of 1344
So question....
I just saw this thread for the first time and the zip files linked in the first few pages aren't actually zip files. They are .exe files.
Is something wrong with the links or am I missing something?
post #935 of 1344
Update- I have all other discs working BUT the animation disc- It still gives me an "invalid disc" error. Not sure what else to try. Enjoying the others, though. biggrin.gif
post #936 of 1344
Originally Posted by purbeast View Post
So question....
Are you meaning the disc "tracker" links?
post #937 of 1344
Yea, I figured they were links to the torrent files in a zip file, but they are all executable files.
post #938 of 1344
Just checked the links, it should take you to a download page where you should click the download button ONLY. And it's indeed a zip file.
post #939 of 1344
You might have a corrupted download. I would try to download it again. If you are burning the segments to BD25 there are no compatibility issues with any BD player the compatibility issues come into play when burning to DVD-DL.
post #940 of 1344
Once you un-zip the files you should have the links for the file downloads. I would suggest you install all the necessary software first. Then you can just double click on the file trackers and the torrent client will start the download.
post #941 of 1344
That link in the first post only sends me to an EXE file. If it needs UAC its likely malware but I don't want to find out. I checked the source there is no zip file for download. Can someone put the torrent on another download site that doesn't try to infect my pc?
post #942 of 1344
this the link... It takes me to the download page where you should be clicking "Low Speed Download" only. If you see any other buttons to fix or speed your computer DO NOT click on those.
http://ifile.ws/ayjvxfx3g8rn/Reference_Links_Complete.zip.html
post #943 of 1344
Alternate Link...
http://www.2shared.com/file/VynSTnXA/Reference_Links_Complete.html
I'll add it to the first page as "Alternate Link" too.
Hope this helps.
Edited by superleo - 12/19/12 at 11:56am
post #944 of 1344
Thanks! I will download that disc again and re-burn. Really digging the others- I had the bass disc in and hadn't checked my volume and walked into the kitchen- have a feeling my neighbors were wondering what H$%% was going on during the depth charges sequence. biggrin.gif
post #945 of 1344
Infection here to....almost...tried to charge my telephone with aprox. US$ 20 / week eek.gif
Maybe try downloading this file...and see if the awesome Bass Disc function properly after dowload ?
http://kringlyd.no/bluraydemo/bassdisc/all_in_one
post #946 of 1344
Well , no go on the Animation disc - I get an "invalid disc error code 800XXXX" - have no idea what's going on. May just have to wait till I pick up some 50G media and give the complete disc a try. The others all work flawlessly. Strange indeed.
MR
post #947 of 1344
Get at least one BD-RE. More expensive, but lots cheaper in the long run than a set of coasters.
post #948 of 1344
Alternate Link...
Hope this helps.
Thank you this helps, don't have to click any executable and worry about malware/spyware smile.gif
post #949 of 1344
post #950 of 1344
Thanks for this! Now I just need to find the same for the animation disc and I'd be set.
post #951 of 1344
What about trying this link to get the animation disc - limited time offer... wink.gif
http://kringlyd.no/bluraydemo/animationdisc/all_in_one/
Edited by Flageborg - 12/22/12 at 2:25am
post #952 of 1344
All I want for Christmas is my two front t...... no, kidding....
post #953 of 1344
Well, now I want it too!
So, where is the link?
post #954 of 1344
So earlier this evening I burnt the Visual one and replaced all the files for the PS3 version and worked fine.
Did the same thing with the animated disc and in my PS3 it said the disc couldn't be read.
Was hype about watching the demo disc only to see that - anyone else have this issue?
post #955 of 1344
I don't have a blu-ray burner, but I would like to see all of the content without swapping discs. I have a PS3. Is it possible to write the BD50 image to a large USB flash drive or an external USB hard drive in a way that the PS3 will read it like a blu-ray?
post #956 of 1344
It's definitely possible. I have this file on a large flash drive and play through my Oppo BDP-105. I'm sure the PS3 can play the file as well.
post #957 of 1344
Do you see the menus too? Or do you just see the video files themselves?
post #958 of 1344
Yes indeed. Selecting the file loads right to the amazing menu screen (with a great audio/visual menu "background" that will have your surround setup working before you even select a demo category.
post #959 of 1344
I guess the PS3 doesn't work that way. I loaded the BDMV onto the root of a FAT32 USB Flash Drive. I loaded it in the PS3, hit Triangle to make it show all, and then was able to browse the file directory. I don't know what to do from there. I tried launching the files in the Stream folder. Some launched, but didn't have sound. Others didn't launch at all. I then tried replacing the index.bdmv and movieobject.bdmv using the ones in the Index and Movie files folder, but that didn't help. I stuck it in the PS3 and got the same result.
post #960 of 1344
Anyone in here have a bluray burner and willing to burn me a copy of this BD50 as well as the Scubasteve demo disc?
Obviously I'm willing to pay you, can be done through paypal. PM me if you could help out.
Also if this is not allowed here mods just let me know and delete this post.
Edited by purbeast - 12/23/12 at 4:32pm
