Ok so this is my question:
I have a Sherwood setup with the RX-4109 stereo receiver (100w on each channel) and the Alto620's.
..and I'm looking to add a subwoofer to it but, I'm concerned on how to hook it up. If for example, I was to buy this active sub:
Wharfedale Diamond SW150
Since there is no LFE channel or separate channel for a sub on the amp, would connecting it like it shows on the manual (I've attached a snapshot to this post) affect the speakers in any way? Would the amp not put out the full power to the speakers because the sub is draining some of it and make the speakers softer? Would it mess up impedance and either make everything softer or make the amp work too hard?
This is obviously my first time doing this so I wanted to consult with people that know about this.
Thank you in advance for replies.
EDIT: If anyone would also like to recommend or suggest a sub, that would be very much appreciated
Preferably sealed box, 10", at least 100-200wRMS, around $500AUD max. It would be for music only. Or would you recommend the Wharfedale?
