AVS › AVS Forum › 3D Central › 3D Displays › Panny 65VT30 3D problems
post #1 of 2
Ok,I just got the Panny 65VT30 hooked up and wanted to check out the 3D function,so I turned on my glasses and pressed the 3D button on the remote,the picture image changes to a blur but dont see the 3d image through my glasses.I wanted to see a sports channel in 3D but its not working,my glasses are charged,what am I doing wrong?
post #2 of 2
You did not select the format for the 3D broadcast you were receiving on your TV.
What 3D channel from what source were you trying to watch?
For example ESPN-3D broadcasts in either 1080i side by side format or in 720 top and bottom format other 3D broadcasts are in 1080 sbs frormat.
Or if your TV has the ability to upgrade a 2D to faux 3D you would have to select that on the TV.
  Back to Forum: 3D Displays
