Hi,
I hooked up a new Motorola DVR from Cox Cable in Baton Rouge, but I can't hook up my VCR/DVD recorder to it, so I figured that I would just use it to DVR shows in the future, including the Super Bowl tomorrow. I was wondering if it was possible to transfer the DVR recordings to an external hard drive on my Mac, and if so, what equipment should I use? I know there's a USB port on the front of the receiver, but I'm just not sure if this will work, or if it will even void the warranty. What should I do in this situation?
