Official unRAID Thread - Page 11
post #301 of 643
Originally Posted by Chrisx510 View Post
What did you guys set your Split Level in User Shares to for Movies,Music and Pics?
Depends on your dir structure. For me:
Backup = 4
Movies = 3
Music = 4
Pics = 5
TV = 3
Here's why: I count the deepest folder AFTER the root (tower). So, it's \\\ ower\\backup (name of the share)\\xanadu\\xanadu.disk.image\\backup 2012-02-24\\files, files, files
That's four levels deep after the root.
Movies: I've got nothing more than three folders deep. I have 75 dirs containing series of films with more than three in a series. SW, ST, Terminator, plus movies I've ripped special features from.
TV: \\\ ower\ v (name of the share)\
ame of show\\season\\files, files, files
post #302 of 643
Lime recommended I do split level 3 high water for movies.
I haven't set up music and pics yet.
My music and pic folders go like this in my whs: Music>Artist>Album>Song file
Pictures>year>event>pic files
Should I set split level to 4?
post #303 of 643
I'm not sure what mine is set for. I'm not even sure if I would have changed it from the default since I was not concerned where the files were located. But if I were to guess it's probably at level 4 since all my content(backups, Bd ISos, pictures, etc) has been stored on all 20 storage drives at one time or another. I'll need to take a look tonight.
But for storing the content I use the high water option "The idea behind "High-Water" is to fill disk1 half way, then fill disk2 half way, then disk3 half way, etc. When you've filled the last data disk half way, then it moves back to disk1, filling it 3/4 of the way, then disk2 3/4 of the way, etc." - Limetech
I really didn't care if a movie folder had a BD ISo on one drive, the coverart on another, and the nfo on yet another disc. My main concern was that I could recover from a storage drive loss or a parity drive loss. And in the tests I did before putting permanent data on the array, it reconstructed the data each time when I replaced a drive.
post #304 of 643
Ok I understand how high water works now.
Can you run scheduled tasks on unRAID?
post #305 of 643
I've got mine at 2.
post #306 of 643
Just leave it alone and move on. you have bigger fish to fry IMO
mine is stock. caring what disk its on defeats the purpose of user shares. This will be interesting for about 1 day and then you will never think of it again.
post #307 of 643
Did you install the subs in your theater?
post #308 of 643
I looked at my split level last night. I don't have anything set for it. It is blank.
post #309 of 643
I have my split level set on three and have my zappiti folders a few levels down so that all zappiti files stay on one disk. I found this speeds up the "Export to Dune" process which, in my case, is really an "export to unraid server" process as I keep the Zappiti files in my Media share.
My share is "Media" and underneath it I have "Movies", "Zappiti" and "TV Shows". Each tv series has its own folder and i don't split the seasons further into folders.
I found that before I set my split levels, I had Zappiti files all over the array and that it would take a long time to export. I could see the server spinning up all the disks and spending a while reading before anything started writing. My Zappiti index is fairly large, I don't recall exactly how many files there are in it but I think it is many thousand, maybe over ten thousand. I have around 800 movies and 400-500 tv shows on the server.
post #310 of 643
Yes all 8 of the 18's are mounted and tested. tonight we finish up a few things and hook up the 4KW amp.
post #311 of 643
Take some pics for me! I'd love to see the setup.
post #312 of 643
Well, I received my ICY BOX today, and installed it. It took some work to install it. I didn't have the correct tools, but I had my air compressor and a grinder and removed a couple of the tabs It fits now, and it looks great. I will take some pictures later.
post #313 of 643
Yea I was told on Lime that the 3 in 5 cages have to modified to fit in the cases.
post #314 of 643
Yeah i was too imptient to wait till tomorrow to get the right tools lol.
post #315 of 643
Here's a picture of my unRaid server with the ICY Box installed!!!
post #316 of 643
Looks good! Now you just need 2 more cages and you'll be set!
post #317 of 643
Chris,
After connecting the server to a 8 port gigabit switch I am having speed issues. Some times the speed is 25 to 40 mbps, and other times it won't go any faster than 8 mbps. It is pissing me off because I don't understand why it is doing that.
post #318 of 643
Chris,
I feel your pain! It was driving me crazy also.
Are the lights in the back of the switch blinking to indicate its gige?
Are all cables CAT5e/CAT6?
Is the computer you're transferring files from GigE?
post #319 of 643
I'm such an idiot. For the last year, I was under the impression my SUPERMICRO AOC-SASLP-MV8 PCI Express x4 SAS SAS RAID Controller was full. ie, no more slots. See the 8 in the model number? Yeah...
Cable and a new WD EARX disk ordered. I can now remove one of the 4 in 3 cages, replace it with a 5 in 3, add a 13th data disk, and dump that ****** PCI SATA controller.
It's a big week here at the Lebowski compound!
post #320 of 643
Yeah, the lights are solid green indicating full speed gigabit. Both my computer and unRaid are gigabit. The cables are Cat5e.
I stopped transferring the file for about 1 hour, and I can back and transferred again and this time I got over 30 mbps. I don't get it!
post #321 of 643
Yea I don't know.. Sometimes my speeds drop down to 24-30MB/s but they average at 67MB/s. Right now I check some files I'm transferring and I'm getting 86MB/s.
Maybe Sean will be able to give you some advice tomorrow.
post #322 of 643
Is that with or without a Parity drive? or are you using a cache drive? I was able to only get over 100 mbps if I didn't have a parity drive.
post #323 of 643
That was without Parity drive.
I just set up my Parity and Cache drive right now.
does anyone know if I can still watch movies during Parity Sync?
post #324 of 643
Oh so i can add a parity drive later? I just assumed that would have to be done as my first step.
post #325 of 643
No you can set up your parity drive whenever you feel like. You can also use your parity drive as data drive if you run out of space, but then you will not have any data back up.
Like right now, I've got .8 gb left. I was going to use my parity drive as back up, but I've decided to take the hard drive out of my 2 tb external drive to use it in my server.
However, now I'll have to buy the unraid license for at least 6 drives.
post #326 of 643
Sure. If someone is able to copy their data to the server, then by all means do it without parity installed. Just ensure the data copied is intact and matches the source. But I think most people have no extra disks, so they must cut, paste, install newly empty disk, repeat.
At least I had to do it that way.
post #327 of 643
Ok guys this is now the Official unRAID Thread
It will be easier for everyone who has questions about unRAID to keep it in one thread. I'll post some info on the first page so new users will have a better understanding of unRAID.
post #328 of 643
BTW: regarding split level and movie jukeboxes spreading files all over the disks. The easiest solution to this is to mount DISK1 as a drive and write the jukebox contents to the one disk instead of the USER share on the unraid. problem solved. no messing with split level is required.
post #329 of 643
sure but more details are needed.
post #330 of 643
I started out with Zappiti files in its own disk outside of the user share but the Dune's can't open more than one SMB share at a time so I put the Zappitit folder in the Media share. I guess I could have used NFS but that seemed more complicated.
