That's definitely what I'm trying to do, but everything that seems to be compatible has been discontinued. Thanks a lot for your time though.
I did some further research and found this board that looks like it might work.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157292
There are plenty of reports of the ASRock 880GM-LE board working, and this is the FX version. I don't really know what the difference is, but there were a couple reports of the current FX version working.
If I go with that board, I'm looking at the following AMD processors; Sempron 145, Athlon II X2 270, and Athlon II X3. I would like to leave the possibility of streaming to my ipad open, which I'm guessing would rule out the Sempron. That would leave the dual core vs triple core. The triple core I'm guessing is overkill but is actually $5 cheaper but is 95w vs 65w for the dual. Should I pay the extra $5 to go with the dual core?
Even though, I am very satisfied with unRaid for my movie and TV Show streaming I do not like the following:
