AVS › AVS Forum › Audio › DIY Speakers and Subs › loud hum when using RMX 2450
post #1 of 10
Hi,
I'm hoping the expertise here can help me debug a problem I'm having
The amplifier on my Def Tech SuperCube I subwoofer died, so I'm trying to replace it using an external amp (QSC RMX 2450). This is how envisioned everything to be connected and just work (it doesn't):
Denon 3311ci subwoofer out on pre-amp
connected to (via RCA cable):
TRS input (1/4 microphone connector) on QSC RMX 2450
connected to (via speaker wire):
Definitive Technology SuperCube I subwoofer (w/o amp; just connected straight to the driver)
This setup causes a very large hum to the subwoofer and barely audible music. So I think haven't consider input impedance or speaker impedance properly or something. Any ideas?
And some more info:
- If I connect the 2450 amp to an iPod with a small bookshelf speaker, it seems to work fine, but I was a bit surprised that the speaker wasn't super loud at full volume. There is no hum and it is loud (actually quite loud) at 100% volume (on the iPod), but I expected to have to keep the iPod at 5% volume maximum because the amp is so powerful for a small bookshelf speaker (probably 50W max input). But maybe this is normal behavior ?
- Any of the 3311 pre-amp outputs (subwoofer, FL, FR, whatever) cause a very loud hum and barely audible music even if I use the bookshelf speaker instead of the subwoofer. This doesn't seem right to me. Maybe I have a problem with the 3311 as well? Or?
Any tips?
Steve
post #2 of 10
You may have an incorrectly wired rca to trs adapter. If it came from monoprice the chance is high.
To do it right, you really need a Dbox or really a Directbox. The transformer type should be OK because it is driven by your avr.
post #3 of 10
Try a RCA>T/S instead of an RCA>TRS adapter.
post #4 of 10
Hmmm. That's a new term to me, but it looks like it converts high-level input (speaker level) to low level (RCA). I shouldn't need that if I'm using the RCA out of the Denon AVR 3311, right?
Or are you suggesting high-level outputs from the AVR would be better?
What's T/S? Attached is from the manually for what I have to work with...
Thanks for the tips...
-Steve
post #5 of 10
http://www.ebay.com/itm/DIRECT-BOX-U...item256c2b4fb5
You are trying to adapt form consumer unbalanced output to pro-type gear which requires a balanced input. Your amp does not have an unbalanced input. you can cheat by getting an adapter, but really, the sure fire way is to give the amp what it needs, a balanced input.
post #6 of 10
-Steve
Tip / Sleeve...... not Tip / Ring / Sleeve.
Scroll down and see the difference in the connectors.
Even though the page is for TRS, they show TS connectors as well.
http://en.wikipedia.org/wiki/TRS_connector
post #7 of 10
Ground loop. This link should be of some help: http://www.rane.com/note110.html
post #8 of 10
Got it thanks. I see the error of my ways now. I've ordered some parts, and I'll update when I get this fixed.
post #9 of 10
"- If I connect the 2450 amp to an iPod with a small bookshelf speaker, it seems to work fine, but I was a bit surprised that the speaker wasn’t super loud at full volume. There is no hum and it is loud (actually quite loud) at 100% volume (on the iPod), but I expected to have to keep the iPod at 5% volume maximum because the amp is so powerful for a small bookshelf speaker (probably 50W max input). But maybe this is normal behavior… ?"
your ipod isn't outputting enough voltage to drive your amp to full power. commercial gear requires higher voltages than does consumer gear in order to hit full power.
post #10 of 10
Try building it like #17 with XLR pin 1 not connected. Worked for me and others I know.
