Maybe it's because he appreciates the fact that the amplifiers in most receivers that sell for less than $1000 are made for about $30 per channel and distort like hell if driven hard (and then there is also the cheesy underpowered el cheapo power supply that has to run them...).
Very few receiver manufacturers even give specs for the amplifiers with all channels driven, because the power supply is so small that the results are a bad joke. The specs they DO give are evasive and designed to mislead the unwary as much as they can.
A few, like Cambridge Audio, are starting to give specs for power output with all channels driven at a meaningful distortion level; that is a start; it is way overdue.
The amplifier quality you get in a cheap receiver is way less than the quality of a pair of $800 speakers. You can get some pretty good speakers for $800 per pair (although you can also buy some for that price that are not so good...). The typical amplifier quality of a $1000 receiver is much lower, IMO.
A great example of the crap that some manufacturers try to pass off as quality is the Anthem MRX700 receiver. This is a $2000 receiver that will only put out 43 watts per channel with an acceptable distortion level, according to actual Home Theater magazine lab test results for all channels driven. Check the magazine review yourself if you don't believe it.
I wonder how many of the people who bought this piece of junk realized that before they bought it? Very damn few, I would bet! I am sure they figured that for $2000, they would certainly get something better...oops! Fooled you, huh??
I am certainly glad that we have Home Theater magazine to expose this kind of gilded turd.
Anthem gets my El Cheapo Grande award for that one. I won't be buying any of their products.
[/QUOTE:]
As an aside, why would anyone spend $2k on an AVR to feed $800 a pair main speakers, is beyond me....[/quote]
[/QUOTE:]
*Dreams of dedicated theater room*
