AVS › AVS Forum › Video Components › Home Theater Computers › Corel WinDVD11 thread
Corel WinDVD11 thread - Page 3
post #61 of 69
AnyDVD (HD) 7.3.7.3 beta
7.3.7.3 2013 11 26
- New: WinDVD 11.6.1.4 is now supported by AnyDVD's unique Cinavia fix
Safe to start using WinDVD 11.6
post #62 of 69
Originally Posted by cybrsage View Post
Why should it have BDMV folder support? Why? Why sMedio should support BDMV folders?
It should have BDMV folder support if Corel wants to sell more copies. I would consider the player if it did.
post #63 of 69
BTW sMedio has not released any update yet. The latest WinDVD version from sMedio is still 11.5.0.61. frown.gif
Edited by kokap - 11/29/13 at 1:31am
post #64 of 69
The Corel update works on both, afaik.
post #65 of 69
Why do you use BDMV folders?
post #66 of 69
No, versions are different - btw I have both versions.
post #67 of 69
You are right, I'm wrong. Corel WinDVD SP3 (i.e. v11.6) can be installed over sMedio v11.5. I 've done this without problem. And sMedio logo have been changed to Corel logo. smile.gif
P.S. I have never received any message about updates from sMedio. BTW sMedio WinDVD doesn't have "Check For Updates" button (Corel WinDVD does).
Edited by kokap - 12/4/13 at 5:35am
post #68 of 69
It really is a confusing relationship - what is the difference between the two groups selling the same software? Check the installation folders too, I bet it moved. Very odd...
post #69 of 69
