What Paul Miller of hi-finews said here:
Is this true in other current Mediatek-based players besides the CA 751 or just his assumption? I've not seen anything here or other reviews that mention it.
Because all Oppo-based players share a common platform it’s reasonable to assume they all share the same anamolies in bass management. So the Primare, like the Cambridge 751BD, offers a drop of –5dB in LFE output relative to all main channels set to ‘Large’ with no re-distribution of centre channel output if this is set to ‘Small’ unless, oddly, the surround channels are also set to ‘Small’. Also, with the LFE/Sub channel turned off, its bass contribution does not appear to be mixed into the main channels unless one or more of them is also set to ‘Small’. The problem here is that if either centre or surround are set to ‘Small’ then the front channels can be overloaded and clip. Counter-intuitively, if both centre and surround are set to small, this does not happen.
