If you goto:
http://www.dlna.org/consumer-home/lo...product-search
Select Search Criteria:
Audio Video System
Play To Receiver
Year 2012
Onkyo Manufacturer
A bunch of new onkyo model numbers show up including:
TX-NR414 *no certification listed but referenced in the other model certs.
TX-NR515
TX-NR616
TX-NR717
TX-NR818
TX-NR1010
TX-NR3010
TX-NR5010
All of these models passed DLNA 1.5 certification around 1/25/2012. Sample attached.
Interesting....
Audio Video System
Play To Receiver
Year 2012
Onkyo Manufacturer
TX-NR515
TX-NR616
TX-NR717
TX-NR818
TX-NR1010
TX-NR3010
TX-NR5010
Interesting....
REG32560343-2.pdf 104.1572265625k . file
I would only guess that high current amps are not needed for the paper weight speakers most are buying these days and with Xovers @ 80hz, the subs is doing all the heavy work, taking the load off the AVRs. Onkyos are built for the masses, not the picky diehards..
"4k" (even though worthless to them) is probably easier to market to joe6pack... "our competitors only do... yada yada yada"... room correction is MUCH harder to sell than "wow, look, 4k!!!"....
), they are happy...
