Ok im getting a Toshiba 42Tl515U and a Logitech Z906 5.1 speaker system...
The specs of the Toshiba 42Tl515U says it outputs Dolby Digital on Optical Out.
The specs of the Logitech Z906 5.1 speaker system says it decodes Dolby Digital.
My plan was hooking up my PS3 and XBOX360 set on Bitstream hooked up to the TV via HDMI...then hook an Optical Cable from the TV to the 5.1 Reciever...
Will I get Dolby Digital 5.1 audio?
