Hi all!
So i have yet to mount my projector on the wall (my shelf should be delivered tomorrow hopefully)..but I'm using the projector anyway--sitting on a small table (much lower than it will eventually be, but no issues due to lens shift..).
So its hooked up to a Yamaha RX-V467BL receiver, using HDMI. I have my xbox feeding into the Yamaha also via HDMI.
I recently moved my FIOS STB (set top box) to a different room, and left the existing coax cable in the first room. I know if I plug this existing coax into some sort of tuner, I can get the basic cable channels, which for now, will be "good enough".
What's the best way to get this feeding into the receiver, so I can then get it on the projector?
I'm sure one option is a PC with a TV tuner card, with an HDMI output.
Any cheaper alternatives?
