AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Another DIY poster/marquee light-box
Another DIY poster/marquee light-box - Page 5
post #121 of 362
bear with me; I am rather clumsy with my Photobucket album:
Here's a detail of how the spotlight frames are assembled:
The spacer frame has been glued, brad nailed and clamped. I originally thought of going with a gold frame (but decided black would go better with my hardwood trim). You can also see here that I am experimenting with some hardwood trim profiles
Here's an example of a poster "stack" before it is clamped into the spotlight frame. Note: the back clear sheet has been replaced with the 1/16" white acrylic "diffusor" panel
Here's the "spacer frame" with the melamine backer installed and my initital LED layout:
Here the unit has been wall mounted, the spotlight frame rails are in the open position. The wiring is less than elegant, but this is the result of my LED strip layout and "home-run" wiring to the incoming power source.
Wall mounted - stairwell lighting off, no diffusor
Now with the diffusor panel in place. Note with the 1.5" strip spacing; that you can just make out the illumination "stripes". I think 1.25" spacing would have made the illumination VERY smooth
And with a very dark poster, stairwell lights on, light box on:
And another stairwell lights off:
And a ticket booth variation (the original ticket booth artwork was done by "Chinadog". This is a beta version - need to use heavier printing stock, so that it will be less "washed-out"
And a few photos of how I handled the power switch (it is installed in the lower RH corner)
And a final photo of a true double-sided poster (The Chicago poster was really 2 "doubled-up" sheets of a single sided reproduction)
Would love to see any/all variations that others may be doing! Thanks for looking!
Next project: an illuminated stairwell railing
post #122 of 362
Very nice, Cuzed. You have me brainstorming and thinking of changing my entire approach.
I have a question for you. I was planning on powering with a 12v/5amp power brick (from ebay). How are you powering this and if you have a brick, where is it located?
Very nice post.
post #123 of 362
Great final write up/parts list. I'm hoping to finish my 2 frames tonight, and start 2 more this weekend. Pictures to follow!
post #124 of 362
Adam,
My light box is in the landing of my stariwell. Directly under the landing is the backside of my Equipment rack for my theater. So; I have a 12v 5amp power brick in the Eq area underneath. My 12 power-feed comes thru the wall into the backside of the lightbox. Hope that helps?
post #125 of 362
Ill be looking for those photos
Good luck in finishing up tonight
post #126 of 362
Sure does, Cuzed. Thanks.
What I'm doing is making one for my sister-in-law for her birthday. She will be my guinea pig for light box creation, but don't tell her! She and my brother will be finishing their bonus room this summer and she absolutely LOVES the movie Amelie. I picked up a double sided poster and want to make a light box. Because of the application this will be "portable." I don't think they'll be hard wiring this in, but I think it would go well in their bonus room, once finished (I hope!).
Thus I plan on having the power brick inside with just the smallish cord exiting out the bottom and plugged into the wall. I'll figure something out, I'm sure.
post #127 of 362
Adam,
Please be VERY careful with heat issues, with the power brick inside the light box cavity. These bricks run quite warm!
post #128 of 362
Adam,
Yes!
I would recommend against putting the brick inside the actual box.
I am keeping mine out and simply making a longer wire run out of the box down to floor level to plug these in the wall with the brick on the floor. Not aesthetically my first choice but necessary.
You could probably put it in the top of the box with "slits" cut into the top of the box for ventilation. Still may get a little warm but would be better than just popping it in there w/o vents.
Greg
post #129 of 362
Adam,
Adding to that...
Heat is as bad for posters as UV light. Posters exposed to heat will fade quickly at much lower levels of light. This is one of the reasons I went with LED, rather than flourescent or conventional rope light.
post #130 of 362
jayn_j,
Great point - never thought of that.
post #131 of 362
Duly noted. Thanks, guys.
post #132 of 362
Hey Guys,
I felt it's time that I chimed in. I don't like to bother my customers when they start a thread about my frames, everyone who buys from me knows they can always contact me anytime.
I just wanted to say Thank You for all of your business and kind words about Spotlight Displays, it means a lot!
And I just wanted to add; don't put expensive posters in any light box for extended periods as previously mentioned. That is the great thing about the frames, you can change the posters in and out with ease.
Great thread Craig!
Semper Fi,
Robert Perry
post #133 of 362
Thanks Robert,
Hope my write up is of assistance to others - and hopefully more project photos will soon emerge
post #134 of 362
Well I finally got my 5 built this w/e (some long hours). They are not hung yet but I am going to try and get to that in the next day or 2 (gotta get through tax season first).
My builds went much much faster for these last 4 then the "prototype" did. Prototype took me at least 5-6 hours. These last 4 probably 10-12 hours total.
Pretty happy with the results and honestly I am not sure I could have done anything different except perhaps the power connection but that is more an issue that I do not have a way to hide the wire in the wall vs dangling down under the frame .. oh well.
I only snapped one pic at the moment but will attempt to do more later as this only shows the frame lit up. I will say this the Wall-E poster is a really awesome looking one when lit up like this. The blue is very vibrant and the image just looks superb. The other poster that I did that turned out really well is the Toy Story 3 one with all the toys surrounding the big 3 in the middle -- this image just pops right out at you.
I think cuzed nailed it with the 4 strands of LEDS, anything less would not have looked right IMHO. I would also like to add that the LED strips were a perfect method for lighting. I have a box I got from someone else and they used florescent tubes, I also tried some rope light I had laying around and neither of them looked as good as these strips.
I want to thank him and jayn_j for posting their plans, pics, and ideas in this thread as I used them as my guide to build my own. I changed things a little bit but overall it was their idea. So thanks!!
Greg
post #135 of 362
Greg,
Looks great. Congrats on getting them finished up. I agree; that Wall-E poster really pops! Please note: jayn-j was the one who urged me to go with the 4th string of LEDs.
Can't wait to see them all installed
post #136 of 362
Greg
Can't wait for the build/rest of the pictures. That poster looks fantastic.
post #137 of 362
Looks great! I've been making my write up in my spare time at work (text is almost done, but I want to take some more pictures). I've got 2 completed and the frames done for the second 2 just need to wire and LED them. My other 2 frames came in from Spotlight as well. If I can get the wife to give me a break (I've spent my last 2 weekends painting our theater room and dining room) Hopefully I can get everything finished up this weekend.
post #138 of 362
My lighted poster box, provides nice "safety lighting" for the upper portion of my stairwell. I also found an additional use for the 12 volt PS - I am using it to feed my powered stairwell railing .
Photos can be found here:
http://www.avsforum.com/avs-vb/showt...1#post21919145
(pg 49, post 1451)
post #139 of 362
Where did you buy that 1/16 inch diffusor panel?
I will post pictures soon of my three lightboxes that i made. They turned pretty cool thanks to all the ideas from here.
post #140 of 362
Here you go:
27” x 40” x .06” thick, pre-cut white acrylic diffuser material.
Evonik Industries, Acrylite, Satin Ice – white (or equivalent)
http://www.acrylite-shop.com/US/us/cutter.htm?$product=o5xxd6hw7og~p&comeFrom=detail
post #141 of 362
elvalle - glad this thread was of assistance - looking forward to your photos
post #142 of 362
Here's my write up (be warned there is a lot of pictures!!!) Let me know if anything is unclear.
Parts List (This is to make 1 frame setup):
- Your Favorite movie poster
- Spotlight Wide Boarder Frame
- 2 pcs 1x2 popular boards, 6' Long
- 1 sheet 4'x8' 5.0mm multipurpose plywood (This is enough for 3 frames)
- 3M Metal Duct Tape (3 wide)
- 1 Can of white spray paint
- 1 quart of black paint (optional, I had some left over from my screen)
- 1 & ¼ Wood Screws
- 20m of Led stripes (I purchased mine in 5m increments, again DO NOT solder together in series as you will see a voltage drop and dimming on the final 2 strips)
- 5V Power supply
- Power Supply Adapter
- Thin gauge wire (black & red) I used 22 ga
- Picture hanging wire and I-hooks
- MonkeyHangers (These things are slick!, but they are optional, any standard picture hangers should work, need 2 per frame)
- Insteon Controlled Power Outlets (optional)
- Wiremold paintable wire covers (optional)
Tools:
- Drill
- Table/Panel Saw (If you want to cut the wood for yourself, I had Lowes do it for me)
- Kreg Jig
- Paint brush
- Soldering Iron
Assembly
1. Cut each 6' 1x2 into the following: One board 41.75 long and one board 27.25 long (I had Lowes cut these for me)
2. Assemble your basic frame with the boards you just cut. Place the shorter 27.25 boards on the insides of the of the 41.75 board. You want the 1 side all facing up or out as they would be in the frame. I used the kreg jig to do this (see pictures below) with just screws. You can do this however you want (nails, old fashion screws and glue, corner or angle braces, duct tape, etc.), however keep in mind that you will be inserting screws into both of the 1 faces to attach your spotlight frame and your ply wood backing.
3. Cut your plywood panel into sections that are 41.75 by 28.75. This should be sized perfectly to the frame you just built. (I had Lowes cut this for me as well, you should be able to get 3 of these panels + scrap out of the 4' x 8' sheet) Do not attach the back to the frame yet.
4. Spray paint one side of the plywood panel white (I did 2 coats). This helps with the reflectivity of the inside of your light box to make sure that you get as much light as possible through your poster.
5. While your back panel is drying take your 3M reflective tape and wrap the inside of the frame. Again this just helps with reflectivity. Be careful with this tape as it feels like tinfoil, but it is MUCH sharper. I got a good paper cut on one of my index fingers from this guy. I cut my tape slightly longer than the inside parts of the frame and just folder it over the sides.
6. Now it's time to marry the reflective frame that you have built to the spray painted white panel. Lay your frame on your work bench, floor, or whatever surface you are working on, then lay your rear panel (white side down) on top of it. Starting in one corner drill and screw the back panel to the frame working away from the first corner ensuring that you are removing and bows/light gaps between the 2 as you go. I ended up putting 5-6 screws down each long side and 4 across the top and bottom. Over kill for just screwing, but it helps eliminate any light gaps
7. This next step is optional. Depending on where you are hanging your finished product, your back frame might be visible from the sides. So to minimize the visual impact of seeing the frame, I painted both the sides and the top of the frame with a flat black paint. I did this after assembling the frame to ensure the edges of the plywood panels also got the black treatment as well.
8. After your black paint is dry, you'll want to either notch out your frame in one of the bottom corners, or drill a hole large enough for the cord for your power supply adapter to fit into. I went with the notch out route.
9. Now on to the fun part-> the LED's themselves! Remember that each LED string will need its own home run back to the power supply. Since we can no longer use the quick connect end of our power supply adapter, let's go ahead and clip it off. Set that aside for now. Our Spotlight frame is going to cover ~5/8 into each side of your light box, so you need to place your first string of lights just north of 5/8's from the long edge of the box. I used a tape measure and a pencil to keep my runs of led's straight. Run the Led strip the entire length of the box, and before looping against the side of the box, measure 1.25 from the edge of your first run to mark your second run. Continue this process until you get to the end of the 5M run.
***Tip*** Just because you can't solder all the strips together does not mean that you cannot solder your home run to 2 strips of 5m runs. So it is important at your points where you have to change to a new strip that you position it correctly that you can solder your wire to the correct leads on the led. This will allow you to make 2 home runs instead of 4. This makes your final wiring back to the power supply adapter much easier (2 wires to 1 instead of 4 to 1)
***Tip*** You'll want to ensure that when you make your curves that you make sure the led strip is all the way to the bottom of the box. This will give you plenty of room to run your home run wires over the leds on the bottom of the box without interfering with too much.
10. Continue running strips until you have used all 4 of your strips, should have ?? vertical strips. If you get to the end you can do like I did and start a run around the outside of the box.
11. Solder your home run wires between runs 1 & 2, and 3 & 4.
12. Run your home run wires back to the notch in your frame you made for the power supply adapter. Connect your home runs to the adapter cable (wire nuts, solder, quick connects, etc.). At this point plug your adapter into the power supply and ensure that all your Led's are working and appear to have the same brightness. Ensure that you wrap everything inside the cabinet in electrical tape.
13. Insert your power adapter into the notch. I put electrical tape over the notch to help keep it in place. I also used electrical tape to hold the home runs into place into the corner.
14. Using the holes that the Spotlight frame has for mounting to the wall, mount the frame to the spotlight frame. I again used 1 & ¼ wood screws. Ensure that you do not drill through any wiring.
15. Mount the power supply to the bottom of the frame. Allow enough cord to be loose so your able to reach a power outlet without stressing the frame/cord. I used small nailed cable clips and twist ties to roughly hold everything into place.
16. Mounting to the wall: I went with the Eye hooks and wire on the frame. I drilled one hole on each side of the frame (~8 from the top) and inserted eye bolts. Then I ran a steel wire between the 2 Eye-bolts . For the wall side I used (2) 35 lbs rated Monkey Hooks spaced approximately ¼ of the way from each outside edge. These Monkey Hooks are easy to install and move and leave little damage to the wall if you do end up needing to move them.
17. Insert you poster acrylics into the frame. Make sure the white piece is in the back, then the poster, then the spotlight supplied piece.
***Tip*** Both the spotlight pieces and the acrylic have protective films on them. The spotlight piece only on one side, the acrylic on both. See attached picture but these need to be remove or you won't get the expected brightness out of them.
18. Plug your frame in. I am using Insteon controlled power outlets to control each frame. This allows me to program them so that I can have them turn off/on with my light switch (also insteon) at the bottom of my stair case (My theater is in a bonus room over my garage). It also allows me to control them through an insteon IR adapter so that when I push play or power on on my Harmony remote it turns all of my lights off (it's a bit too bright with all 4 of my frames on while trying to watch a movie).
19. To help hide the cords that are a ways away from my outlets I used some paintable wiremold wire covers. This gives it a final touch of clean to improve the WAF effect.
20. Enjoy and move on to your next theater project! (I think I am running out of things to do???? Suggestions?)
post #143 of 362
DaDeuce,
Excellent write up. Very nice result!
The Insteon and Harmony combo seems like a good idea. Also; like the idea of the wiremold to to hide your wiring.
A few Questions; Did you go with a 3 amp or 5 amps PS brick? Curious how warm it gets?
As for things to do next:
I got a chuckle out of that, because that was my question as well. What I then did; was to add a lighted stair-rail (you did say your theater was upstairs, didn't you?). Check out my thread (sig file) to see how I did it.
post #144 of 362
Cuzed and DaDeuce,
Question for you guys ... I am really concerned about my power supplies. I have 2 types here. One a 5amp and one a 1.6 amp one.
The 5 amp one gets super hot (like nuclear meltdown hot) within 2-5 mins.
The 1.6 amp one gets really hot but not as bad within 15 mins.
IMHO both get way too hot for my liking.
I am running another 1.6 amp PS (same as the one above) on a set blue LEDs for my riser at it never gets hot. It is only running 2 strands of LEDs. The frames are running 4 rows of LEDS.
Any thoughts or a suggestion of a better power supply that doesn't get so hot it will burn my house down?
Greg
**EDIT - Guys BIG problem with this setup for me. My LEDs and power supplies came from LEDLAND on ebay. I have now discovered in addition to the above info that the PS is running WAY TOO HOT. I was just looking them over and one of them has completely melted down the plastic around the plug. This is with the 4 strips of LEDs "homerun" to the power connector. I am hoping I can find a suitable PS to deal with this if not I have to go to another plan which may mean rewiring these things so that they use 2 PSes instead of one. Again it doesn't matter whether I am using the 1.6a or the 5a one they both get way too hot.
Please lmk if you guys are experiencing anything similar.
post #145 of 362
Cuzed and DaDeuce,
Greg
GCS,
Well mine have gotten warm there is no melting of anything or temperatures anywhere near that that would suggest melting. Do you have a picture of what actually melted?
Also what type of usage were you putting to yours? Mine will literally be only on for a few minutes at a time while getting ready to watch a movie or powering down the theater. Where yours on for a constant period of time?
post #146 of 362
Cuzed and DaDeuce,
Greg
GCS,
Something doesn't seem right with the combination you are using, generating that much heat. I understand that the 1.6 amp unit might get dangerously hot. But the 5 amp unit should not get any warmer than a laptop brick. The fact that both are very hot is really odd.
I initially tested my 4-string light box with 2 different supplies. My tests consisted of a 4 hr run each:
The first PS test was with a 3 amp plastic brick, it got rather warm about the same as my PS laptop. I then came across an adjustable generic laptop PS brick that twas rated at 3.5 amps, thought it might run a bit cooler - but it actually ran warmer than the 3 amp unit? I came to the conclusion that these ratings are less than accurate (and some are optimistic).
In the end I knew I wold be adding a 5ht string of lights (my stairwell railing). It was only because of this 5th string that I decided to upgrade to a 5amp PS. In this case my PS is located in the equipment room out of plain sight. Therefore; I chose a 5amp supply in an aluminum case with some heat sink ribs on the unit. This particular 5 amp supply is running 5 strings, and it has gone for up to 4 hours and only becomes warm to the touch but not hot.
The only thing I can think of is a wiring issue, or more likely; the LEDLAND strips you bought require more current?
I will grab some photos of the PS's that I have mentioned above, and will try to post these tomorrow.
Good for you for being careful and catching this hazard. Can you post a photo of what has begun melting from your setup?
post #147 of 362
What is melted is the actual plug that goes into the wall.
Both wires of the LED strips are simply wired up and brought "home" to the power connector and connected via a wire nut - nothing special.
Well I would like to have my frames on as long as we want (not just minutes) so this is an issue for me.
Cuzed lmk what you find out about your PS.
Greg
post #148 of 362
Greg
Greg,
I did not mean to sound like I am ok with the plug melting with a long period of use, I was just trying to convey my usage up to this point to see if I could potentially have the same issues down the road.
Back to your melted PS. You said the plug melted, did it melt due to being in close proximity to the power brick or did the heat travel up the power cord itself? How long had the frame been on when this happened? I have some time tonight to "watch" my frames and can test my units as well. Also are your leds wired directly to the ps or do you have one of the "quick" commect adapters in between? You also have multiple units correct? Is the heat an issue on all of them or was this unit significantly hotter than the others? It could be a bad power supply or your plug could have come wired incorrectly (there is no reason for heat to be generated at the wall as there is no "work" being done on that part of the plug. But if the plug was not built/ wired correctly it could have a short in it that was generating the heat, which means my units as well could have this flaw.)
post #149 of 362
Greg,
No worries ... I was just conveying how we plan to use ours as well, my bad.
All 5 units act the same. The cord is almost as hot as the power brick itself. Only one of them has had the the actual wall plug melt the plastic. The power connector at the frame and the frame and LEDs themselves are all fine.
We can't have them on for more than about 15 mins before they seem to get so hot its unbearable.
Each LED string has 2 wires coming off it and then each of those wires is wire nutted together with the power connector (all whites together, all reds together etc). These are a connected via the power connector I purchased from LEDLAND with the power supplies and the LEDs.
Greg
post #150 of 362
Greg
Greg,
I will experiment tonight and let you know my findings. I believe I have had mine on for more than 15 minutes when I was testing and don't recall having this issue. I will admit that I also would not have been paying attention and would have probably unplugged the unit without messing with the power brick.
