AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Another DIY poster/marquee light-box
Another DIY poster/marquee light-box - Page 14
post #391 of 395
What gauge wire are you guys using to make the connections between LED strips and to the power supply?
post #392 of 395
I think I used 16g from the power supply to a wire nut then 20g from the wire but to each strip.
post #393 of 395
Figured I'd post a link to my movie poster construction rather than recopying everything over here. I may drop in some final pictures once I have them because not everyone will want to follow my whole process.
Edited by vanice - 2/20/14 at 7:11am
post #394 of 395
No link posted. Do you mean the posts from #1228 in your build thread?
I find it fascinating how different needs drive very different designs. Yours show very nice craftsmanship.
post #395 of 395
Yes, post 1228 (it's in the word link). Thought by putting that number in the link that it would automatically scroll down to post 1228. Guess I was wrong.
Appreciate the compliment. My frame doesn't have a lot of detail to it but adds just enough I think. I was lucky to come across this thread early on in my design process so that I could incorporate spaces for them in the wall that help keep the depth down and allow me some flexibility on material choices sense everything is not visible.
