AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Cheapest substrate for 47"x110" screen
post #1 of 8
What would be the best/cheapest way to get a screen with dimensions 47"x110"? All the Wilsonart and foamboard/gatorboard options are over $100 + oversize shipping. Is it possible to make a screen this large without paying more than around $50-$60? I want to have money left over for paint.
post #2 of 8
5 x 10 x 3mm Sintra is $50.00 most places. BLack Out Cloth might be another possibility.
What City do you live close to?
post #3 of 8
I'm in Bellingham, WA, but I can drive down to Seattle and the greater Seattle area if necessary.
post #4 of 8
Found a supplier of Komatex. $40 for 3mm 60"x120" and $70 for 6mm. Will the 3mm be ok or do I need to shell out for the 6mm?
post #5 of 8
pay the extra 30 for the 6mm.
post #6 of 8
At that price, get the 6mm. Much easier to work with.
post #7 of 8
Even if I'm mounting it to a rigid frame? I'm fine spending the extra $30; i'm just curious if it makes that big of a difference. Odds are I'll be upgrading later this year anyway to a larger screen so this is more a temporary solution for about 6 months or so.
post #8 of 8
yes. ESPECIALLY if you mounting it to a frame.
  Back to Forum: DIY Screen Section
