Originally Posted by
beerhunt
I was thinking of buying 2 pairs of the fs51s along with the c21 and a higher end subwoofer but i'm not sure what sub to get! My particular room is 14'x15'x8' so one sub should do it! If or when I move into another house with a bigger room i know the 4 fs51s will b sufficient ....sorry to get off topic, thanks again Hubertoliver!...I hope the 1122 isn't overkill for this setup, comments?
The biggest problem is not what for sub to buy, but where to put it !!
I have used subs on the cheap side and subs on the high side, had one sub had 2 subs, had 3 subs and NEVER could get them to work so that i had a good bass around the room.
Used stuff like Audyssey XT 32, RABOS ect but never could get the sub to work in the aria where i whas sitting.
I get bass in front of me, i get bass behind me, never in the sweet spot.
Now i kicked out my subs and have great bass all over, no blind spots.
Ok, not as low as a LFE sub will do but i do get a audioble 35 to 40 Hz bass respond and thats ok for me, and this is all over the room, no bass dips !
So get a set of good main speakers and dont burn your fingers in spending $$ on subs you will never hear playing in the sweet spot, but that my personal opinian.
Just want to point out there is a life without subwoofers, and a nice one it is
