Originally Posted by
Hockeytown Fan
I'm having a similar problem, My x360 slim dont "see" the hd dvd add on. if i go to the settings and check hard drives it shows my hd dvd add on's drive space but I cant for the life of me find where to launch a movie from... I've trying searching and searching the dash and the internet for a solution and come across nothing but "go to video tab". Its like my x360 only see's it as a hard drive.
Hmm, it sounds to me like you might have one of those 360s with small internal memory unit. Mine says 319 megs, but some of it's taken.
Just to reiterate, you go to the dashboard, then Video, then My Video Apps. If you don't see the HDDVD player in there, it's straight up broke, son.
Edit: I've bought 2 drives on ebay since I posted this thread and tried them both on older 360s and a slim, and they both work as expected. Basically these drives just seem to go bad sometimes. If the eject button constantly flashes, I think that's some kinda 360 error code, cos even though the drive would work on PC the 360 still wasn't havin' it.
