I'm trying to reconcile how we think in terms of peak output for program peaks, versus known levels of power compression in speakers with continuous signals (eg pink noise for 5 minutes).
Planning for peaks in system
When choosing speakers and amps for a room, people often neglect to consider the maximum level the system will need to handle. This is a combination of what volume level they're aiming for (average dialog levels with 20dB peaks for home theater), the size of the room, listening distance, speaker placement, room treatment, and amplification.
Since almost all systems can handle the average dialog levels, it's handling those peaks that we should be concerned with. Many speakers don't have enough sensitivity, thus requiring enormous amps to handle the peaks, or their power handling doesn't allow them to take the peak signal without compression and distortion. It's the latter that I'm concerned about here.
At what level do speakers compress?
I've heard it a couple times on AVS that speaker power compression occurs at 1/8th to 1/10th power. I wasn't sure whether that was continuous or peak, and with what level signal.
Recently, I've re-read the Audioholics article Loudspeakers & Power Ratings: What's the Deal Part II.
In it, Gene DellaSala and Paul Appolino reference three JBL Pro speakers where the power compression is given. It's in terms of fractions of continuous power rating. For instance, the JBL woofer 2226. It's rated 600w AES cont. pink noise. They give three amounts of power compression:
60w 0.7dB (1/10)
300w 2.5dB (1/2)
600w 4.0 dB (rated power)
This means with this 97dB sensitive speaker, instead of getting 113.3dB at 12 feet with 600 watts, you're getting 109dB (I realize this is more than enough SPL, but it's just an example, and it's applicable to 90dB speakers too).
This is after the AES pink noise signal 50-500Hz for 5 minutes.
I made a Google spreadsheet showing the power compression of three speakers referenced in the article, as well as another JBL one I'd researched earlier that only shows compression at 1/10 and 1/2 power.
This would seem to confirm, at least for this speaker, compression starting at 1/10th rated power continuous. There's also distortion of varying amounts at different frequencies: at 40Hz, 3rd harmonic distortion is at -20dB (1%), at only 60w of power. They don't give us the distortion at full power.
What does this mean for peaks?
On the one hand, one could apply this 1/10th rule also to peak power. For most speakers, this would severely limit the level it can reach, resulting in diminished peaks. That peak that was supposed to be 15dB over the average level only reaches 12dB. And the odd-order distortion makes us wince.
On the other hand, a 1 second peak of an orchestral stab or a film's gunshot is not the same thing as a 5 minute continuous signal. We know a speaker can much better handle a brief spike, where the voice coil wasn't heated up much previously, and has time to cool down in the subsequent seconds.
What I'm Asking
Is anyone familiar with what sort of compression and distortion result at what typical fractions of peak power handling, with peak signals for brief periods, like the THX burst signal they use when testing / specifying speakers?
Is it less compression for a 1 second signal with a 20dB crest factor? Or more compression, because we're talking about 4x the watts as the continuous signal?
60w 0.7dB (1/10)
300w 2.5dB (1/2)
What I'm Asking
