http://www.avsforum.com/avs-vb/showt...2#post21634252
Featured Stories
How Good Is the New AntiMode Dual Core EQ? - Page 2
- Ovation
- Trader Feedback: 0
- offline
- 3,181 Posts. Joined 3/2004
- Thumbs Up: 12
- Select All Posts By This User
That's very similar to how I feel as well. I've vacillated on getting the 8033 for a while now, but always come back to the thought that $350 wasn't commensurate with what you gain. The prices for the new unit strikes me as astronomical, and it seems like the wiser choice would be an AVR using one of the more advanced versions of Audyssey. At least for what I'm attempting to achieve anyway. The Anti-Mode products might be good, but it's hard for me to fathom they're that good.
At Home Theater Shack, the creator of the REW software, who strongly counsels the use of REW with a BFD parametric EQ, as an inexpensive and effective way to EQ subs, reviewed the 8033 and reached, IIRC, about 90% of what he could with REW + BFD. He did it in ten minutes from opening the box. BFD/REW would take him, by his own statement, several hours to equal--and more time to improve upon--the 8033 results. And he's an expert.
I chose the 10 minute option.
Having the 8033 let me have an EQ for my sub for 10 months before getting my new AVR. It also allowed me to choose a less expensive AVR, knowing that my sub was taken care of. From what I've read (a lot) and what I've heard, I would need Anthem's ARC or XT32 to do better for my sub. The former (MRX) lacked other features I wanted and the latter was out of my price range.
I don't think the new Anti-mode will seriously dent sales of mainstream AVRs with Audyssey or other systems. I do think it offers an interesting product for certain setups (like my living room--someday) and I'm glad to see it come to market. If it works as well as my 8033 in a broader capacity, it'll be a winner.
- Mupi
- offline
- 3,030 Posts. Joined 5/2003
- Thumbs Up: 18
The price on the Denon 4311 is very tempting. But if I cant EQ the mains below 40Hz then I am not going to bother with XT32.
- spyboy
- offline
- 6,930 Posts. Joined 2/2002
- Thumbs Up: 18
When AVS Forum member Kal Rubinson tested the AntiMode 8033 for Stereophile magazine this is what he said:
"When I restored the 8033's EQ, each pedal tone became distinguishable. There was a salutary effect with low percussion and winds, and, of course with film sound effects."
"In summary, the DSPeaker AntiMode is a dandy little device for taking care of the major influences of room modes. It is incredibly easy to use and reasonably priced."
Of course, reasonably priced means different things to different people...
- pokekevin
- offline
- 4,515 Posts. Joined 6/2011
- Thumbs Up: 34
- ggsantafe
- Trader Feedback: +1
- offline
- 492 Posts. Joined 2/2008
- Thumbs Up: 13
Check the AVS classified section - there's an 8033 for sale at a very reasonable price.
- spyboy
- offline
- Thumbs Up: 18
- pokekevin
- offline
- Thumbs Up: 34
- ggsantafe
- offline
- Thumbs Up: 13
I don't think so - unless you are making frequent changes to your setup, you only have to run your sweeps once, and then you are good to go. I think the price on this unit is a great value.
- pbc
- offline
- 5,180 Posts. Joined 7/2002
- Thumbs Up: 19
I too prefer the 10 mins option. I did try the BFD 1124P and FBQ2496. I also bought the DEQ2496 later as it has a 31band digital EQ in addition to a 10 band PEQ. I was uisng the DEQ2496 mainly to lower the mid range of the mains and used the Antimode 8033 for the sub. Now I am using the Audyssey on Denon 3310 to use the main and the sub (on top of the 8033) but this is only for movies. I dont like a flat response for music. So the option to tweak the correction in Antimode 8033 is attractive. I dont need to spend a lot of money on top of XT32 to get the pro option.
I have no issues if the price isn't a concern with you, I was just stating that the $1200 reg price seems steep for what you get, IMO. I too dislike how the current crop of AVRs set cross overs. No ability to EQ below the xover Audyssey deems the -3db point of your speaker in your room is (i.e., even if the Denon does allow you to set an xover all the way down to 40hz, if Audyssey only EQ's say down to a FR above 40hz, you're screwed in any event), and no ability to mix x-overs if you wanted to say use your mains down to 40hz and your subs in conjunction up to some different low pass, higher than 40hz.
What mains do you have btw that are clean below 40hz? Or do you simply not listen to music anywhere near reference most of the time so aren't concerned if your speakers can't necessarily get close to reference levels at 40hz without distorting?
- Ovation
- offline
- Thumbs Up: 12
I leave mine on all the time. No fuss, no muss. The stereo one does have EQ for higher up the frequency band than the mono model (somewhere into the 200s, I think, while the mono one EQs up to 144hz or so), so if that's a need/concern, it is worth going for that model. It also has a few other configurations not available on the basic model, IIRC, but I had no need for them.
- Mupi
- offline
- Thumbs Up: 18
I have the Klipsch KG4.5's and KG5.2's. Yep I dont listen at reference level at all. My listening level is much much lower than reference level. May be 70-75 for music and at the most 80 for movies.
- Mupi
- offline
- Thumbs Up: 18
http://www.avsforum.com/avs-vb/showt...3#post21636863
- nismo604
- member
- offline
- 405 Posts. Joined 2/2007
- Thumbs Up: 14
So where do you see Denon 4311 for $1300?
BTW I am not interested in Audyssey products by Onkyo or Integra as they dont give an option between Audyssy (flat option in Denon) and Audysey Reference. I also prefer to buy from popular online stores and I dont see such a low price for 4311 (no refurbished 'B' stock)
xx09 Onkyos do allow the option to choose between the Audyssey reference and flat curve, albeit with different names.
Movie=reference
Music=flat
- Mupi
- offline
- Thumbs Up: 18
- pbc
- offline
- Thumbs Up: 19
- pbc
- offline
- Thumbs Up: 19
So if you want to use your speakers "full range" for music listening, you already are with Audyssey engaged. Your choice as to whether you want to turn off the sub.
I don't know what sub you have, but if it's more capable than your Klipsch's are below 60hz or so (and it should be, else it really isn't a subwoofer or you've got one that likely won't help your already relatively potent speakers), for movie watching at levels above say -15 to reference, change the speakers to small and add a 60hz or 80hz cross-over.
I'm somewhat confused as to what you're trying to get at in your other thread. Everyone is telling you if your speakers are being set to Large, then Audyssey is determining what your -3db point in room is of your mains, and applying EQ all the way to that point. You DON'T want it trying to correct below the -3db point that it calculates in your room irrespective of what the manufacturer claims their speakers are in an anechoic chamber which is usually i) exaggerated at best and ii) relatively useless since once you put them in room the game changes. You run the risk of damaging your speakers by doing so.
In essense Audyssey it's doing what you want it to do. It's just not telling you what the -3db point is since it's setting the speakers to Large or allowing you to change that -3db point. Heck, if you want to do that, put the 2 speakers closer to the corners, that will lower your -3db point a bit though it might cause other issues.
If you want to spend $800/$1200 on the Anti-mode for this reason only, go ahead. But as far as I can tell, you're going to have the same issue. It also isn't going to "tell you" what the -3db point is which it will also EQ down to and no lower.
It will give you a low resolution graph that will likely be difficult to read. But you could do the same with a $50 SPL meter and REW free software.
If you felt the Anti-mode would do a better job at EQ'ing than Audyssey, that's a different story all together.
IMO, the Anti-mode dual core seems to be geared to 2 subwoofer systems where the subs are not placed symetrically from the LP and therefore require significantly different adjustments to each sub, or for 2 channel systems which utilize a processor that does not have its own version of EQ for the main 2 channels.
Having said that, again, if the $800-$1200 isn't an issue, by all means, buy it and report back on which device you prefer for your two channel listening. Note, however, that you'll probably have to turn Audyssey "off" when listening in two channel mode (unless the Denon has some sort of pure direct?) otherwise you'll be doubling up on the EQ. Which may or may not be a good thing.
Actually, I'm not even sure how you'd incorporate a dual core for just your main 2 channels the more I think about it. Will you turn off the dual core entirely when listening to anything but 2 channel? Or just run the dual core on your mains after applying Audyssey? If you're planning on leaving the sub on for your music listening, that makes things even more difficult.
- Mupi
- offline
- Thumbs Up: 18
"In addition of being able to correct a pair of full-range speakers (or a dual-subwoofer system) in an acoustically challenging environment, it offers a wide variety of adjustments for the overall sound"
- pbc
- offline
- Thumbs Up: 19
Antimode also is not going to tell me what the -3db point is that it measured but I can at least select my range based on the specs of the speaker. I can also play with the range a bit and also use a SPL meter to get some quick measurements just at the low end to confirm. They do claim that it can be used for a pair of full-range speakers.
True, you'd then be relying on the accuracy of the published spec of the speaker versus the actual measured spec in your room by a fairly sophisticated piece of software which was specifically designed to do just that.
Without REW, finding the "-3db" point of your speaker will be challenging at best. Actually, even with REW it will be challenging. I.e., what if you run a db sweep at 70db, and the -3db is 36hz (I think that was the published spec of your nice 5.4s), but if you run it at 90db, it's 45hz?
Anyhow, I think you may be chasing something that the Antimode won't really help you with since Audyssey is already doing it for you, except the issue appears to be that a) you can't control how low the software EQ's your mains and b) you don't know what that is as Audyssey won't tell you (would be cool if the AVR incorpoated some sort of "exact -3db point as per what Audyssey says" sort of display!).
How would you use the Antimode Dual Core on your mains in conjunction with your Denon is the most difficult thing to figure out IMO.
If you want to listen to 2CH music with your mains EQ'd, I think you'll have to turn the Antimode on when listening in some sort of Pure Direct mode and turn off Audyssey in the receiver.
If you want to listen to music in 5.1 or 7.1, or movies, turn off the Antimode and only use Audyssey I guess.
If you want to listen to music in 2.1 with your mains EQ'd by the Dual Core and subwoofer also EQ'd by Audyssey, that's where things get a bit more confusing.
- bsoko2
- Trader Feedback: +2
- offline
- 4,220 Posts. Joined 4/2007
- Thumbs Up: 17
- trallala
- offline
- 31 Posts. Joined 12/2007
- Thumbs Up: 10
- bsoko2
- offline
- Thumbs Up: 17
- bsoko2
- offline
- Thumbs Up: 17
- trallala
- offline
- Thumbs Up: 10
About an hour ago I plugged in my dual core and ran the calibration - i'm still a little queasy...
I'll get to it in a bit
Very easy setup; single rca cable from my Onkyo receiver to the dual core and from it, two rca cables to my two SVS SB13-plus subwoofers. Language selection->calibration, select 2 subs mono mode brings you to the level adjustment screen. With the dual core calibration volume/level set to max, the "level ok" label flickered on and off so I raised the volume on the subs 6 db and as expected I got "level ok" at a bit lower level. So, I hit the ok button
What happens next is a little foggy but i'm sure I sat on the floor next to a subwoofer amazed at the staggering pressure the subs did to my room! When the calibration started to cycle left and right sub very smoothly I felt motion sickness kick in.
No, i'm totally serious and as far as I know not at all "sensitive" to bass or high volume. This was just way more intense than the cinema ever have been in my experience. Since I've never been even close to that kind of output from my subs before, it's good to know what they really are capable of.
Anyway, I think a bit of a waring to people living in apartments is in order; it's loud and in my case lasted somewhere around 5 min, possibly 6-7 min.
Oh, calibration is a series of slow going low to high freq. sweeps - I think I counted 6 sweeps in all, aprox 1 min each.
I haven't really listened to the system after setup - I just ran a quick 3 point audyssey calibration with the Onkyo and reset the crossover from 40 to 80 Hz on my front and center speaker. As soon as my head and ears clear up a bit i'll have a proper listening session.
I attached a picture of the calibration results, you should see it below if all went well.
Oh, yeah.. the missus ran out of the apartment during the fist sweep giving me the evil eye as she went. When she came back she told me i'm crazy and that she expects at least a few complaints coming in to our landlord
With luck it's possible to export the calibration file and re-load it should a firmware upgrade, lightning or other reset the unit, and require a new calibration. I really don't want to do it again in a apartment.
Â
Â
edit:
Â
I just wanted to mention I will re-calibrate at a lower volume setting during this summer. I think the curve will look a lot smoother If I can tune in a volume level just below the point where everything in my apartment shake 'n rattle like crazy.
Some time and energy to determine a better location for one or both subs would be great (~60Hz dip). Also, I'll do the calibration in 0-120Hz range rather than full range (I found the range selection in the calibration\advanced menu). I'm planning to upgrade my onk 5007 receiver to a 2012 model as well (looking forward to have a go at XT32!).
Edited by trallala - 6/14/12 at 1:22pm
- lovinthehd
- offline
- 3,389 Posts. Joined 12/2007
- Thumbs Up: 72
With luck it's possible to export the calibration file and re-load it should a firmware upgrade, lightning or other reset the unit, and require a new calibration. I really don't want to do it again in a apartment.Hard to imagine someone with two subs like that in an apartment at all. Sounds promising, look forward to your further review...
- trallala
- offline
- Thumbs Up: 10
Got a reply from DSPeaker; unfortunately, there aren't any other codes already programmed into the dual core. Adding specific remote codes in the next firmware version (small changes such as more languages) is "fairly high priority".
Sounds good enough to me.
I have no problems waiting a bit for it because the volume control is very responsive and it works very well having volume up/down bound to the upper arrow up/down keys on my Logitech 900.
Well, they are pretty small compared to other subs, ported ones in particular. It's not totally over the top is it?
I probably don't need the headroom/increased output but I figured having two and manage to get some sort of overlapping of each others weak ranges would make it worth the loss of floor space.
- lovinthehd
- offline
- Thumbs Up: 72
I
I wasn't thinking of the size of your place or the subs...but rather the thinly insulated walls/floors/ceilings that have accompanied the apartments I'm used to...maybe your apartment is different.
- a1bert
- Lurker
- offline
- 129 Posts. Joined 6/2008
- Thumbs Up: 10
- bsoko2
- offline
- Thumbs Up: 17
- craig john
- Packer Backer
- offline
- 9,501 Posts. Joined 10/2003
- Thumbs Up: 73
Anti Mode Dual Core pings each channel seperatly (2 channel) and you can group like subs together in each channel. You can setup 4 different presets and different calibration curves within each preset (house curve lift of +3, +6, +9 db or across the boad lift with the same incerments from 15 hz on out to the end). Also has volume control for each preset. It doesn't lend flatness across the board into the other channels and the SQ is excellent. I have used SMS-1, Audyssey Pro, Audysssey Sub EQ, AS EQ-1, and the standard Anti Mode 8033S and found the Anti Mode Dual Core to be the best for me and my room with 3 Submersives.
You *need* to get a measurement system so you can post some measurements. I would love to be able to "see" the differences.
Craig
- How Good Is the New AntiMode Dual Core EQ?
Recent Discussions
- › Official Vizio M-Series Razor Mxx1i thread 41 seconds ago
- › Bizarre prices on Ebay 50 seconds ago
- › Atlantic Technology owner's thread. 1 minute ago
- › List of HDTV's with 120Hz native refresh ability (forcing... 1 minute ago
- › How Does Watching Movies in Your Home Theater Affect How Often You... 1 minute ago
- › NAS as HTPC? (XBMC on QNAP TS-x69s) 1 minute ago
- › Bookshelf speaker recommendation for $400 budget for the pair in a... 1 minute ago
- › October fun: 31 days of Horror, Blood, Guts and Gore! (and zombies,... 1 minute ago
- › AE Group buy 2013! 1 minute ago
- › Best 2-zone receiver for the money - impedance matching controls 2 minutes ago
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
