Originally Posted by none74
XBMC doesn't work, at least, not for me, not without reading and reading and reading and reading and HOPING someone has EXACTLY the same setup as me so I can get it to ACTUALLY WORK and produce a great image when playing back without stutter.
XBMC doesn't work, WMC7 JUST WORKS, once you add Shark Codec's....I get hd mkv playback using MadVR, beautiful quality, no stutters, subtitles if needed, over my network, EASY. XBMC to do that would mean I'd have to go back to University and get a degree in computer programming, and even then it wouldn't be as high quality playback....
First of all you mean MediaBrowser+MC7 as both are needed.
There are many people who have exactly the opposite experience. With XBMC I don't need to add any codecs and it gets all metadata and plays back everything after a 5min config. It's all a question of what you are used to, but you can't claim that XBMC is any harder.
Let's see the steps required for playing back media from network. I'm not including BR/LiveTv here as for those MB is better (due to integration with Windows).
1. Installation - easy for both
2. Add source directories - same for both
3. Fetch metadata - both do it automatically
4. Add/configure codecs - not needed for XBMC
5. Split according to directory structure - XBMC does it by metadata, MB is maybe more flexible here
6. Add a new skin/addon - both do this, though I find XBMC faster and has much more variety
7. Remote setup - WMC is probably easier here
So I don't see how XBMC is any harder.
Also XBMC is the origin of HTCP frontends AFAIK and has the most active development, without it none of the others would exist. The sheer variety of addons in XBMC is reason enough for me to use it. It's also worth mentioning XBMC is totally free and standalone, you don't even need Windows and it can run on cheap old hardware.
