AVS › AVS Forum › HDTV › HDTV Technical › Dish Network VIP211k & OTA reception
post #1 of 11
Hello everyone,
I recently terminated my service with DishNetwork and was only asked to return one of my two Dish receivers. So I now have a Vip211k which I would like to use for my Panasonic plasma monitor since it doesn't have a built-in tuner.
Would I be able to use the 211k as an OTA tuner for my Panny plasma even though I no longer have Dish service?
-Josh
post #2 of 11
I am not sure about the 211k but some of the dish receivers will keep getting over the air stations. They still need to be connected to a dish getting the satellite signal. You also don't get any guide data.
John
post #3 of 11
If you've already terminated service, try it.
post #4 of 11
Looks like a no-go guys. As soon as I turn the receiver on, it tries to establish a satellite connection. I can't seem to get it to leave that "screen".
Maybe I can sell this guy on fee-bay and pick up a Channel Master instead...
post #5 of 11
once you have a satellite connection it will get past that screen and the OTA should work. You wouldnt have any guide info but it still would work.
post #6 of 11
Do you still have the dish connected?
post #7 of 11
Yes the dish is still up on my roof with the wiring intact. But i have returned the module (attached to the dish) that receives the satellite signal and feeds it to STB receiver. So when i turn it on, the 211k stays in the 'acquiring satellite' screen with now way to cancel it...or IS there?
post #8 of 11
Because you returned the module that receives the sat signal, the receiver is not seeing the signal it needs to work; it has to be connected to a functioning dish.
The only solution is to get another Dish Network LNB unit, which will depend on what dish you have on the roof.
post #9 of 11
? is exactly what I was thinking....
post #10 of 11
If you hit the guide button does it kick out of that?
post #11 of 11
I've hit every button I can think of. It will not leave that screen. I think I'm SOL guys.
  Back to Forum: HDTV Technical
