Hi, I recently purchased the Yamaha YHT-196 and I have had it for less than a day now and so far it seems to be good. This is my first home theater system.
I could not find any reviews online for the Yamaha YHT-196, but I did find a lot of reviews for the Onkyo HT-S3400 and it was a mixed response. A lot of people found the Onkyo system to be amazing while others complained it either sounded worse than previous home theater systems they owned or the Onkyo speakers started to sound staticky after 2 weeks of use. Some even said their Onkyo HTiB died after less than one month of use.
I also went in store to hear the Onkyo HT-S3400 and it sounded very dull to me. No matter how loud I put the volume up, it still sounded very bad and such I decided to buy the Yamaha YHT-196.
Which one is better? The Yamaha YHT-196 or the Onkyo HT-S3400? The only difference I found was the Onkyo receiver supported Dolby TrueHD while the Yamaha one did not.
What do you think? Should I return the Yamaha HTiB and buy the Onkyo one or should I stick with the Yamaha one?
