Ok here we go. I just got finished putting the studs up in my basement for a dedicated home theater. The room itself is 12' wide and 20' deep and has two walls, one side and the back, butted up to my exterior block walls. I put 2x2 studs on those walls and 2x4 on the other two walls. The ceiling is at 7'3" to the floor joists.
Now to the part i'm not for sure on. This room in directly below my main family room, so I would like to stop most if not all noise from leaving the HT room. But I would also like the best sound quality inside the room. I'm not going to be listening to music in the room, it's only for movie watching and game playing. I'm setting it up for 7.1.
My questions are these.
1-What material should I use before I put up drywall? I've been looking around and was planning on using acoustical barriers from silentsource.com. But that is going to be like $1400 shipped. Ya I know, wow. I've been reading a little about the 1" duct board and leaning that way but don't know if it will do the trick.
2- I was planning on doing two sheets of dw, but I was just going to use drywall screws for hanging them. Whats this green glue stuff I've seen people talk about?
3-Should I do all the walls the same. Like front, back and the two sides?
4-Ceiling. All my lights will be wall sconces, so there will not be any penetrations in my ceiling. Maybe my projector mount, but not sure yet how I'm going to put that up yet. Should I use the 1" duct board plus the layer of dw on my ceiling too?
Thanks for the help, I'm getting excited to finish this room up as I just ordered my projector a couple days ago.
