I'm in the process of building a HT. The room is 23x11x8.
There is an HVAC system running across the room, basically above the couch, which travels left to right. There shouldn't be a lot of reflections off that since the speakers are not pointed towards it.
However, I do have some concern about reflections in the room. I read a few articles on the topic, but would like some recommendations on what to buy or build. I would like to know specifics on how many and what size of sound absorbers to use. I don't know a lot on the topic, but I figured (2) 24x36x2" absorbers on the back wall would be a good idea, and maybe two bass traps in those back corners. Maybe these? http://www.amazon.com/Corner-Bass-Tr...9002004&sr=8-4
Maybe these as well, or build my own. http://www.amazon.com/Auralex-Studio...9002004&sr=8-5
As far as speaker setup, "toe-in" of the front and rears is for reducing reflections, is my guess. Always made sense to me to do it. So I plan on doing that.
I would really like some info. on where to buy or what to build and any suggestions to change what I plan to do.
Thanks, much appreciated.
Looking at screen wall.
. I thought maybe I could do a darker gray on the ceiling, but still undecided. The screen wall will have a painted white screen, probably make a good 3-4 inch border for that, in black.
