AVS › AVS Forum › Video Components › Home Theater Computers › Mfusick's New HTPC Build !!! (Pictures included)
Mfusick's New HTPC Build !!! (Pictures included) - Page 6
post #151 of 180
pics of the server and HTPC build should be up soon...
post #152 of 180
I ended up using an old Thermaltake ARMOR 10 bay case I had left over from a core 2 duo E8400 build years back. I took the Core2 and put it into a coolermaster Elite case and made it an office PC.
I re-used this case below for server. I had to do some drilling and mods to it but it worked great.
I added two 4 bay HDD cages... So 8 HDD's plus the stock 2 and a 2.5" SSD. Only 10 HDD's to start but I have some room for 4 more.
post #153 of 180
post #154 of 180
This was me just messing around in the build. I actually did it different/ better as final
post #155 of 180
My little ATX Asrock Board looks so small in this case!
post #156 of 180
The Scrap pile and bone yard
post #157 of 180
post #158 of 180
post #159 of 180
I already had a few SATA cards.
I ended up using a 4XSATAII PCI and a 2XSATAIII PCI=X
post #160 of 180
post #161 of 180
Don't mind the mess or the unfinished basement. It's a work in progress. I just slapped that countertop down without even screwing it or installing it just to have a work space for a bit. lol.
post #162 of 180
post #163 of 180
post #164 of 180
post #165 of 180
I ended up hacking the WHS2011 to install to a 60GB SSD I bought for $48
I won't use a HDD for anything but storage. I happy I did that. I almost used a 320GB WD blue.
post #166 of 180
It comes with a SATA end that allows it to be used internal or external when you take it apart without voiding the warranty or breaking anything.
Pretty cool.
post #167 of 180
I also built a cheap HTPC in an APEX case with an i3
Here is the back:
Here is the top
The front with no cover on it:
Top down no case cover:
FRONT view:
The whole thing was very cheap. Less than $300
post #168 of 180
Some more parts stacked on top of my treadmill in the basement waiting for assembly
post #169 of 180
29$ and 5$ shipping makes this case one of the best deals out there.
Comes with a 500 480watt PSU and is easy to build in.
Great value for a budget build.
post #170 of 180
I bought a pair of G630's. One I used in my personal HTPC. I ended up going with an ASROCK EXTREME Z68 + Gkill RipJawz 8GB with a ANtec 300 case and Antec ECO PSU.
post #171 of 180
I also ended up using Muskin Memory in the server and some Crucial for another PC.
post #172 of 180
post #173 of 180
$99 is a steal for this. Great Drive for my personal HTPC
post #174 of 180
My HTPC case. Antec300. Nice case for the money but poor quality control.. Mine arrived defective. PITA
post #175 of 180
post #176 of 180
Got this PSU for $29. Nice deal
post #177 of 180
First motherboard I chose was Z68 Asrock PRO
I could not get it to turn on. I sent it back RMA.
Turns out it was the crappy Antec300 Case. Power button on case is broken.
I ended up upgrading the motherboard and the new board had a power switch on the motherboard. I hit that in frustration and it popped right on no problem. I later tested and confirmed it was indeed the Antec300 Case.
Antec son.. I am disapoint.
Here is the original Board before the RMA
post #178 of 180
Another Motherboard. Nice board.
post #179 of 180
I also borrowed my Dad's i3 laptop because it was slow as dirt.
I changed out his drive to a 120GB SSD. Clean installed office pro and set it back up how it was with all his documents. Then returned it.
I never told him what I did. I wanted to see if he noticed. lol.
Personally I don't know how people use or tolerate these stock laptops. What a difference an SSD can make.
post #180 of 180
I have a couple more projects I been working on including a DUAL 120GB SSD OS install on RAID0.
1000mb sec benchmarks speeds. Pretty cool stuff.
Cost me $69 x2 for two Vertex3's. So that is $140 plus tax for a 240GB SSD with 1000MB/sec transfer speeds.
Close to double that of most $140 128GB SSD's in both capacity and speed for the same price.
